14 E code keeps flashing all the time. Tried reset no luck
Sadly, what is an error code on one device may mean one thing and something quite different on another device. You have posted in the Office category and the two primary devices which pop up if you google just the error code involve a refrigerator and an air craft. It is always helpful to identify the device, brand, and model when posting a query. If the device is a Samsung fridge, the error code appears associated with the ice maker sensor. The repair involves replacement of a part, the ice maker control assembly, a task you are unlikely to be doing around the office. However, without knowing the brand and model, this is clearly guesswork as to whether it applies --just as I am guessing aircraft is not involved.
SOURCE: D80 lcd flashing "F- -"
ive had this problem before, on my camera it means that the lens isnt rotated all the way onto its engaging point on the lens mount... it gets a little loose and shifts out of the way sometimes...
SOURCE: siemens gigaset 4215
Then the base is bad. I have 1 base like that also... nothing can be done other than send it out to be rebuilt.
Sorry,
Geno
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will
stop working and lock the functions (clean light flashes 7 times, all
buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring). It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
SOURCE: Sony Trinitron wont power up
the red light flashing tells you and a service person why the tv will not power up . if you have test equipment to work on electronic equipment then we can move forward if not ,your tv will need parts replaced or board replaced . you dont have a failure that you can change a setting or push a reset button to repair . you will need to get in there with equipment inject signals,look at waveforms ,and check voltages . and know what you are doing with the information you gather ...the other answer you need to send it out for repair .... most repairs on this set will run 100.00-200.00 for common problems .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
SOURCE: r7184b just got oil reset wont reset tried main
if the reset is a square button see if this will work. hold the button in, the green light will go out, count to 30 by 1000s, (1001-1002-1003 etc.) at around 1030 the green light should flash once. when it does release the reset and wait about 10 sec. the pump should start. if it runs for about 15 sec. and shuts off the pump needs to be bled. good luck, hope this helps.
