what do you mean by problem wireless driver need a bit more info and what os you are using you could try updates or some sort of driver app like driver magician there are a lot of free driver apps out you could try
Overheating
When the CPU overheats then it will shut down (i.e. thermal
overload) and won't boot up again until it has cooled down. If this is the
problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged
with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure
the vents are clear and dust free. Use a small brush and can of compressed air
to do this.
It may just be overheating. The fan inside might be not working properly or it could be clogged up with dust where the vents are. If you feel confident enough it would be worth you stripping it down and checking the insides.
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
