Question about Radio Communications
Set the display on my bearcat BCB895XLT - Radio Communications
How do i reset uniden bearcat bc355c. To factory settings?
SOME, of the Bearcat radios you could hold down the "2" and "9" button while turning it on - worked on the old units; I don't know about the newer ones.
Apr 12, 2015 | Uniden Radio Communications
Uniden cordless phone do not receive incoming calls. Do not disturb in written in display
go into your phone settings on the handset and turn off do not disturb or try to find a restore defaults link.
Oct 27, 2013 | Uniden Bearcat BC72XLT NASCAR Scanner
I dont know how to set my uniden bearcat scanner codes
Since you didn't specify the model of your Uniden Bearcat, I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 07, 2013 | Radio Communications
Uniden bearcat scanner 800 xlt comes on but screen will not display
This may require return to Uniden for replacement of the screen
Oct 28, 2012 | Uniden Radio Communications
I have a Bearcat Scanner (Uniden Bearcat BC145X) how do I set up the chainals
The BC350 is a pre-programmed scanner. You cannot program it in the usual manner (direct keyboard entry of each frequency), but you can transfer displayed frequencies in the SCAN or SEARCH mode to a PRIVATE bank. Detailed instructions for operating your scanner are in the factory manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 10, 2010 | Uniden BC350C Base Scanner
How do i program a bearcat 210 scanner to new frequencies
Simply have it on the channel you want to program and push the correct set of numbers like 162.550 and press the Enter key and it is done repeat this for each channel and you are done.
Aug 23, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Uniden bearcat scanner BC148XLT-1 Can't program it because it is locked out
Try manually unlocking each channel by selecting it and then pressing the LOCKOUT key. That will normally clear the channel for programming. If that doesn't fix the problem, power the scanner OFF, then press and hold the MANUAL, 2, and 9 keys while powering the unit ON. That should restore the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
Bill B
Aug 11, 2010 | Radio Communications
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
Need to know how to put codes in
If your scanner is the BC350C (the section you posted in), here's a link to the owner's manual which will give you detailed programming information:
If you have a different model Bearcat scanner, try:
1. Push MANUAL to stop scanning and advance to the channel that you want to program.
2. Enter the desired frequency, including the decimal point (e.g., 156.015).
3. Press E or ENTER to set the frequency.
4. Repeat the process, starting with 1 above to select the channel.
NOTE: With some Bearcat scanners you may need to press the E or ENTER key before entering your frequency.
These are general steps that work on most recent Bearcat models. If they don't work on yours, try different variations. You can also check Uniden.com -- they may have an online manual that you can download and print.
Apr 25, 2009 | Uniden BC350C Base Scanner
Bearcat scanner 210xl program manual
Here Is A Users Manual For The Uniden Bearcat 210XL 18 Channel Programmable Scanner.
Just Follow This Link And Save or Print It Out In .pdf Format.........
I Myself Used My Dell Laserjet And Printed It As (2) two Sided Pages And Have A Nice Looking Manual. It Is A Complete Instruction Manual That Tells You How To Set It Up!
http://www.repeater-builder.com/uniden/pdf/uniden-bearcat-bc210xl-owners-man.pdf
Jan 24, 2008 | Uniden TRUNKTRACKER III
Radio Communications Logo
52 people viewed this question
Top Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
