Nokia 6500 Slide Cellular Phone Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia 6500 i dont no how to insert a sim card into a nokia 6500 slide
Anonymous
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Sep 17, 2009
Anonymous
Master
Level 3:
President:
Answers
1462
Questions
Helped
390185
Points
4707
Here is the manual for Nokia 6500 slide
http://nds1.nokia.com/files/support/china/phones/guides/Nokia_6500slide_UG_hk_en.pdf
In page 11,you can find guide how to insert SIM
ENJOY RATE THIS SOLUTION
RNJ VINOD KUMAR
3helpful
How i unlock my nokia 6500 slide ?
There are lot of ways to Unlock the Phone from Network lock,But i suggest the Network Unlock code to unlock the Phone from Network ,you can get the unlock code at here
Mobile-Unlocker and follow the instructions below and unlock it step by step.....
1 - Switch on your Nokia 6500 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6500 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Unlocking instructions for Nokia 6500 SLIDE:
Note :For Nokia 6500 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6500 SLIDE
2helpful
3answers
Hi there..i have a signal problem with my nokia 6500
Try checking with your service provider if there's any outage problem in your area. Which is possible since you don't have any bars for signal on your phone.
My nokia 6500 is not reading d memory card
dear,
check you memory card..is it properly plugged or inserted..if you are still in doubt then check your memory card by putting it to the card reader or on other phone. Check it please..
goodluck...
hope it will help so dont forget to rate it..
How to formate a memory card in nokia 6500 slide phone . i dont find memory with logo in setting.please help me more
Use a card reader on a computer and insert this card from your phone. If you right click on this phone icon in the computer, one of the options is format. I would recommend deleting files rather than formatting, which reduces life of the card.
Insert correct sim card
It means your are not inserting it correctly or the chips on the place where it has to be inserted are not working
2helpful
2answers
My SIM card is active in other phones but when i put it in the nokia 6500 slide it keeps saying SIM registration failed, i need to know how to unblock the phone as i have rang orange and they say the SIM...
You need to buy an unlock code for the carrier the phone is locked on. eBay is usually a good place to start looking, and these codes are relatively inexpensive
I want to remove my sim but dont know how
ure sim card should be located underneath your battery.. remove your battery cover (which is on the back of your phone), take out your battery, and you should be able to slide out your sim card..
Phone says no sim card inserted
Your phone will operate without the sim card. But you won`t be able to make calls etc.
Make sure it`s inserted correctly and use a dry piece of cloth to clean the sim card.
Hope this helps
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
