Question about Mitsubishi Televison & Video
Error code 17 on Mitsubishi model wd-73736 How do I fix it
6ya staff
SOURCE:
Anonymous
  • 1066 Answers
SOURCE: I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Posted on Mar 27, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: I replace the bulb and I'm getting a blinking
That code can often be caused by failed capacitors on the power board which will cause the 34 error for lamp abnormality. The V26 Power repair kit at www.tvrepairworld.com may fix that issue. The kit contains the replacement capacitors and has the CD with instructions.
Posted on Dec 15, 2009
Barry Compton
  • 125 Answers
SOURCE: Mitsubishi TV DLP 73736. No picture but has sound
Replace Lamp Mats has them for $99.00
1-800-628-1118
Posted on Mar 24, 2010
eagle338
eagle338
  • 4889 Answers
SOURCE: Hello, Mitsubishi DLP Mod.#
This is definitely a case of digital board malfunction. Since the problem only appears after a while, the input and processing circuits are ok and the problem is being triggered by faulty logic control circuitry on the digital board. Replacing the same should resolve the problem. Would you like to do it yourself?
Posted on Aug 29, 2011
daddytech
  • 280 Answers
SOURCE: Mitsubishi dlp wd-65638 with error code 61. What is this error code? How do I fix? no picture or audio.
if the power LED is flashing green then there is a circuit or board that either has a blown fuse or relay. if it comes on solid red when you turn on the television then the Lamp inside is burned out and needs replaced. Before you spend all the money that changing the bulb would cost i would invest that money in a good LED Smart TV instead. Sometimes you just gotta let that old technology go away.
Posted on Dec 30, 2014
I replaced the lamp for my Mitsubishi 915b403001 tv and the "lamp" light is still on
you need to reset the timer
I will tell you the way to reset the timer ,Pls let me know your Projector's Model
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 12, 2013 | Mitsubishi 915b403001 Lamp For Wd-73735 /...
White spot on mitsubishi wd 73736 dlp
need to replace the dlp chip under 200.00
Aug 28, 2013 | Mitsubishi WD-73833 73" HDTV
How do you correct the light engine, it was
Thats a mechanical adjustment called keystone. The service manual sjould outline that proceeduer for you. You can get the service manual by download link from www.servicemanuals.vstore.ca
May 24, 2010 | Mitsubishi WD-73736 Television
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
My check engine light won't go away, keeps saying code 17?
Your engine is staying cool too long/closed loop temp not reached
probably need a new thermostat.
Apr 18, 2009 | 1996 Mitsubishi Eclipse
Mar 27, 2009 | Mitsubishi WD-73736 Television
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
