Panasonic Toughbook CF-51 Notebook Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i power up my cf51 it doesnt boot.
When i power up my cf51 it doesn't boot. i get a steady power light but no others. i read something about a "screen magnet" getting stuck so i smacked the edge of it and tried powering up again, it did the same thing, just had the light with the lightning bolt on it (far right) and the two lights on the front of the laptop the battery and the other lightning bolt. only lights that light up.. i smacked it one time while it was on out of frustration and it booted right up. all the lights to the left lit up went out and the hdd light lit up and i saw the windows screen. botted fine no problems, no problems in device manager. it even did windows update for 3 hours. THEN it wanted to REBOOT..... and it started all over again. so instead of beating the snot out of it i figured id ask for some help
  • c_logsdon Sep 17, 2009
    I reinstalled windows, but before i did that i restored it back as far as i could. no help. upon reinstalling windows it still did not boot up. i have a smack it right around where all the lights are to get it to boot up. When its NOT booting up, it goes like this " I hit the power button for a split second all the lights light up like normal, imeediately after they all go out besides the power light. then if i hit it enough hard enough under where the lights are right abover the keyboard under the power button, it will eventually boot up.
Anonymous
Level 3:
  • Master 375 Answers
  • Posted on Sep 17, 2009
Anonymous
Master
Level 3:
Answers
375
Questions
0
Helped
203314
Points
1545
Load Ubuntu LiveCD and mount the windows HDD and save all personal files onto a DVD. And then reinstall windows. This will fix it. Thank you.
  • Laurie Watson
    Laurie Watson Jun 13, 2014
    It is not a windows problem...the laptop doesn't boot. I have one with the same problem and altho I would like to beat it up, I will refrain for the moment and try to search out answers. I will update this if I find them.
Steady green light in the back--have reset the memory cards and checked all connections. I took cover off plugged power in and the green light comes on steady once again but th e fan doestn run and the...
replace your power supply you have lost your 12 volt supply coming from your power supply
but you have your other power supply voltages still working
My father-in law's Gateway Essentials 800C doesn't power up. Power light is steady amber. Is it the PS? or Is it a motherboard?
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Dell inspiron will not boot
Try this:
tap F8 on boot and go to safe mode with networking. If you are unable to load the OS is seems as thou you have a corrupted OS and will have to reload it. I hope you have backed up your data and have a recovery disk.
I have an hp m8425f and the tower won't turn on,
Remove the Power Cord, then press and hold the power button for 30 seconds. After 30 seconds, plug the cord back in and press the power button. If it works, you had a Static Charge Buildup that had to be released.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If the above two steps fail, pull the main power plug that comes out of the power supply and plugs into the motherboard. The end that plugs into the motherboard is probably about two inches long, Grab the release latch on it and press it while pulling up to unplug it. Wait 30 seconds then plug it back into the motherboard. Push it back in firmly.
Try turning on the system.
Toshiba l355d - s7815 won't boot and screen doesn't light up
From your description you have a motherboard issue, the only way to rectify this, it must be replaced.
2helpful
2answers
Screen does not light up - stays black
remove charger,
remove battery
press and hold the power on button for 1min
place battery
press power on button,
if it doesnt light up, then check your memories chips. try another one
good luck
I believe that my display module is flawed
the problem is its a lcd liquid crystal leak you need to replace the lcd you can get them from dell.com
Acer aspire doesnt boot at allllll, pleaseeeee helpppp
Dear Friend,
After studying your case i feel that there is problem with your hardware may be mother board so before doing any more RND its better you show it to the Service Center
1helpful
Acer Aspire 5050 won't boot at all
Hi there
Try taking the battery out and power it on AC only, post back with the results.
Good luck
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
