Health & Beauty Logo
phillip oliverio Posted on Oct 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a prowler 3410 that will only activate the charger if the key is turned on in the headlight is on otherwise when it is turned off and the key is off the charger shows to Green line.
Rob Hill
Level 3:
  • The Master 1,480 Answers
  • Posted on Oct 12, 2019
Rob Hill
The Master
Level 3:
Answers
1480
Questions
0
Helped
518128
Points
3838
Hi Phillip, the charger is supply the power for your scooter to turn on , you need to check the batteries and battery connection, how old are the batteries and when were they last charged ?
Regards
Rob
2003 Pontiac Montana won't start
Sounds like your new battery is flat. Try this. Sit someone in the car with the headlight on. Stand in front of the car and look at the headlights. Have the person in the car try to start it. When you hear the click, do the lights dim to a glow worm? If they do, your battery is flat. Whenever I get new batteries, I charge them overnight with a 6 amp charger.
Or when you reconnected the battery, the key wasn't in the ignition, and now your anti-theft is activated because it doesn't recognize the transponder in the key.
I need a service manual for a Prowler 3410 scooter.
Hi GRAB & HOLD THE SEAT SWIVEL LEVER.till the seat rotates..AT THE SAME TIME LIFT THE SEAT..cheers.
2answers
ActiveCare scooter will not go forward, but will go backwards, does anyone know what is wrong with it?
hi Carol, sorry but i need to knwo what controller is fitted to that scooter then i can more accurately advise you ? remove the seat with care regarding your back and the rear cover t, we looking for a black or blue unit that all the wires go into ?
Please give me a Id of the controller used..
Regards
Rob
Helping me to Help you ...
Need help on how to splice sound system input power into aux circuit on 2003 FXST. I only want system powered up when bike is in "aux/on" position
I have added a charger socket for my phone/sat nav and wired in a relay that is activated when the lights are on. The live side of the relay is spliced into the headlight feed. The charger socket is then wired to the outlet side of the relay. No lights mean no power to socket. That way, when the key is off and bike left there is no chance the attached equipment will be left on and drain the battery. If you can do this then the radio will turn off when the lights are off. I do drive with my lights on at all times, but if you don't then just turning them on activates the relay.
When charging electric mobility scooter, the yellow light never changes to green.
defective batteries or charger, try to charge the batteries one at a time with a car charger, if they charge then replace the charger, if they do not then the batteries are in need of replacment.
HOW DO I ADJUST SEAT HIGHT ON PROWLER 3410 SCOOTER
hi, the following link will contain all of the information you require
http://www.thescooterstore.com/pdf/scooters/manual/ProwlerOwnersManual.pdf
Regards
Please rate my assistance.
5helpful
2005 chevy uplander how to program key FOB?
Get a trick-Charger and hook up to battery, turn new key in ignition switch to "on" but do not start engine, turn headlights on ( thats why you need the charger) and leave it like that for 100+ minutes.
That should do the trick and reprogram the new key, otherwise dealer only! about $130.00
1helpful
I have an old nokia 3410 i wish to get unlocked
the default lock code is 12345 try it.
go to the settings and activate "security keyguard" to lock the keys with security code
Top The Health & Beauty Experts
Paul Carew
Steve Sweetleaf
Steve Sweetleaf
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
