Regarding your recent inquiry about the Canon 240 (black) or 241 (color) ink cartridge ink alert/error condition and the inability to print to your Canon MX452 printer, to reset the cartridge ink low/empty alert message condition, depending on your printer model, we suggest you follow the documented procedures below and/or provided on Inkjet411 at the following link. http://inkjet411.com/?page_id=1765
Essentially, in most cases, all you need to do is press the 'Stop/Reset' button (triangle symbol inside of a circle) for 5-8 seconds and the ink error ("ink has run out", etc.) indicators should extinguish; two common reset procedures are provided below (please refer to both videos): http://inkjet411.com/?page_id=1765
If you have already attempted the 5-8 second printer reset without success, then refer to WORST CASE SCENARIO section below.
ADDITIONAL NOTES:
NOTE 1: Providing you can still print, you will need to wait until the "ink has run out" message appears on your computer, before activating the 'Stop/Resume' button for 5-8 seconds. However, if printing is not permissible, then please keep reading....
NOTE 2: If you are able to print the internal self test print, this will demonstrate that the ink cartridge is 'at least' partially functioning. If this is the case, then we suggest you continue printing until the software prompts you to press the 'Stop/Reset' button for >5 seconds. For poor print quality performance issues (as you indicated in your inquiry), we suggest you run a nozzle/cartridge clean test from your Canon software, followed by printing our 'Ink Recovery Test' print: http://inkjet411.com/wp-content/uploads/2013/02/Test-Print_CMYK.pdf
NOTE: To rule out connectivity issues, please ensure BOTH carriage/flex cables (point where the cartridge connects to carriage inside the printer) and BOTH ink cartridge rear electrical contact surfaces are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
WORST CASE SCENARIO - INTERNAL ELECTRICAL FAILURE OF INK CARTRIDGE:
If, after performing the suggested 'reset' procedures above, you still have an error condition which prohibits computer/host based printing (or permit copy/scan functions), then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
CAUTION: Be advised, the use of Canon compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations which may contain volatile organic compounds, or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
If you do need to purchase a new ink cartridge (to save on ink costs), we suggest you try a USA remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and come with a 1-year warranty.
Alternatively, if you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
Please let us know if you have any questions regarding the technical information provided above by sending an e-mail to us directly: [email protected]
Simple, turn on your HP OJ 6500A printer and open top cover...carriage should move to cartridge access position. If not, then the service station may be in the way or the PRINTHEAD assembly is not properly locked down causing an error condition. Power supply could also cause this kind of failure.
For information
on North American ink refill services (i.e. HP920 and HP920XL ink cartridges) at a major retailer near you (should you
wish to save ~50% on ink costs), general printing problem resolutions or advanced
HP Officejet 6500, 6500A, 6500A Plus, 7000 and 7500A printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error
bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
You can refill an Epson ink cartridge, but you will need an "SK168-II Chip Resetter" to clear and reset the cartridge memory chip. The cartridge will still show as empty after refilling and not work until it is reset. The refill ink should have come with an instruction sheet. If not check their web site for instructions. If the cartridge has been empty for a while and you can hear the sponge inside when shaking it - it has fried out and cannot be refilled. The dust particles from the dried sponge will plug up the jets.
Some aftermarket printer ink sales web sites will offer the chip resetter for Epson printers.
i've quite come across this kind of problems many times. Simply replace your cartridge with new ones or try that old one to dip its head in the hot water for sometime.
