I have a moultrie d40 trail camera and when i set the time and date it never changes.what am i doing wrong.
Looking at front (inside of outer door) the D-40 has very different look than my I-40s and 60s, but bet programming is near the same.
1st, turn red arrow switch to"setup";press select button until time/date appear,here, not sure of programing...pressing select at this point may take you out of time setup mode.Try the up/down buttons below the display once right time is displayed, press select.
Hope this works, and good luck.
I have read through the manual and could not find any special action required the register the change.
The only thing that I can think of is, did you continue to press the "select" button until you have left the time set routine? If you do not exit the routine then it seems likely that changes will not be recorded.
After each digit are you pressing "enter?select"
