Question about Seth Thomas Home
Chimes and pendulum work, but hands won't move on Seth Thomas Westminster ave Maria regulator wall clock with hermle quartz 2115 works.
6ya staff
SOURCE:
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Setting the correct time on Seth Thomas clock.
Correct technique definitely is CLOCKWISE ONLY. You are unbelievably lucky person if did not damage striking mechanism within 25 years while adjusting hands anti clockwise. If I'd have such a luck, I'd try to play lottery. :))
Posted on Feb 04, 2010
Testimonial: "I was surprised by the answer. I can't recollect where I got the advice to set it by counter clockwise. Will follow you guidance. Thanks"
wedgetarian
SOURCE: seth thomas autoset wall clock not functioning.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Posted on Jun 10, 2010
hadjibaba
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I have an Elgin Westminster
I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
Posted on May 18, 2011
Billy Bignose
SOURCE: we have a Acctim barrery
Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
Posted on Oct 10, 2011
Seth Thomas wall clock with pendulum that runs, but won't tell time. Replaced batteries Stopped working when knocked off the wall & fell straight down to the floor. Any hope, without major expense?
likely - if it was an expensive clock - you may want qualified, trained, experienced clock repairman to work on it - take it to one, and ask for estimate.
Mar 26, 2018 | Cars & Trucks
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
    Howard Miller Clock Parts ' eBay
    www.ebay.com/bhp/howard-miller-clock-parts
    eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
    Clock Repair & Replacement Parts - Movements, Motors ...
    timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
    Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register ยท My Cart.
    Jan 27, 2016 | Westminister Time Warp Shelf Clock
    Need to speed up my seth thomas wall mount hand wound clock
    Can't Tell From Picture, But If It Has A Pendulem Ajust screw clockwise for faster (screw is last on arm)
    Mar 15, 2015 | Seth Thomas Audio Players & Recorders
    Bulova wall clock hands won't move
    I haven't much experience of this type of clock. A friend has such a quartz pendulum clock and I was surprised to discover the pendulum has no direct mechanical contact with the clock motor and as long as the motor draws some current from the battery the pendulum will swing due to the resulting influence of a small electromagnet.
    I guess the quartz mechanism is at least electrically ok but somewhere there is a mechanical fault preventing the hands moving.
    A typical quartz clock motor is fairly simple and dismantles easily to reveal only a few internal parts that can be examined under a magnifier to determine the probable fault - dust, burrs or excessive wear.
    It is also worth making certain the clock hands do not bind on each other or the clock face.
    Jul 08, 2012 | Home
    We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
    Nov 19, 2010 | Watches
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Apr 21, 2010 | Watches
    Home Logo
    56 people viewed this question
    Top Seth Thomas Home Experts
    Tom Chichester
    Dan Apthorp
    Simon Atkinson
    Simon Atkinson
    Are you a Seth Thomas Home Expert? Answer questions, earn points and help others
