This is another MS nasty for all the deployment folks pushing XP SP3 to
computers with UAA HD Audio devices. Yes SP3 will support the devices and
the drivers are included however,, the patch IS NOT included! The update to
KB835221, KB888111 doesn't link to the download but instructs you to call MS
Support to get the patch which doesn't work on SP3.
This patch is required before any of the HD device drivers are installed.
for details you can look at:
http://www.tech-archive.net/Archive/WinXP/microsoft.public.windowsxp.setup_deployment/2008-05/msg00216.html
You have to install the microsoft uaa driver patch for service pack first, then install the drivers
What I
could recon from your question is that your audio driver is not installed
in your reformatted PC.
Please
be informed that any Driver software depends upon the PC make, Motherboard type
and Operating System. You need to know all the three information's to do get
going.
Please refer the above image. It is clearly seen that your Laptop does not support Windows XP. It only supports Windows Vista or higher.
Thus I would request you to use Windows 7 as OS because all the hardware drivers are available for windows 7 by Toshiba including the Sound.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1854869&rpn=PSU30U&modelFilter=U305-S7449&selCategory=2756709&selFamily=1073768663#contentArea
This is the Direct Driver Download link for your laptop. Here you need to select your Operating System (Windows7) and all the drivers will follow in the list below. Here you will also find windows XP but you will see that a lot of drivers are missing including the sound driver.
So, my suggestion is to upgrade to windows 7.
Good Luck.
thanks for the help, pankaj.. yes, there was a problem when i tried installing the drivers from the motherboard cd.. it showed the UAA patch in red n "this will work only for SP1" was written over it..
where can i get a patch dat wil work for SP3?
i got the solution.. thanks, both of u!!!
i changed my registry entry to show my windows as a SP2 pack.. then installed that SP2 patch n my drivers.. the reverted the registry back to SP3.. got the answer at a link at Dashken.net...
