Kitchen Appliances - Others Logo
Susan Hall Posted on Oct 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On Salton Waffle maker WM8Bel there is a standby light and a cook light. none of the manuals listed talk about the standby light and it never goes off.
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Oct 11, 2019
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567370
Points
3788
I would suggest that the standby light is there to let you know that the unit is ready and waiting for you to set it and for use. Much like any appliance such as TV,s etc have standby lights. Any appliance with a standby light use a small amount of power. When not in use, its recommended to turn it off at the power point to save a bit of power.
5 Related Answers
Anonymous
  • Posted on Feb 09, 2008
SOURCE: Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Anonymous
  • Posted on Aug 25, 2008
SOURCE: Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Anonymous
  • Posted on Apr 18, 2009
SOURCE: NEED OWNERS MANUAL
Plug it in, and wait for light to go off..
When light is off, pour (aprox) 1/4 cup batter on each of the 2 (of the 4) waffle panels on the bottom surface. Close lid; then, per manual, wait about 90 seconds. The light may flicker on/off while baking but disregard. You may experiment with different times by observing "steam" from coming out of baking area.
Remove waffles with a plastic spatula (as knives may scratch the non stick coating)
When cleaning, power unit off.. Do not immerse unit in water. Wipe down with a soapy/damp cloth.
I tried using non stick spray and it seemed to make them "soggy"; it also required up to 2 mins (used a "sand timer") then flipped waffles, then another 2mins..
Jim
  • 158 Answers
  • Posted on Sep 24, 2009
SOURCE: Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Anonymous
  • Posted on Jan 06, 2010
SOURCE: Lost instructions for proctor-silex waffle maker
You can download instruction manuals at proctorsilex.com under their custromer service tab
Purchase manual
Appears to be the same thing with a different model number.
http://www.salton.com/files/documents/WM-1075%20Booklet%20EN.pdf
1helpful
I have a pre owned wm-4. No owner's manual. Can the plates be removed for cleaning?
These instructions are taken from a WM14 waffle maker, maybe they will work for you. It doesn't say anything about removing the plates:
"Wipe Cooking Plates with absorbent paper
towel or a soft cloth. Although the Cooking Plates are coated
with a non-stick coating, some batter or ingredients may still adhere
to the Waffle Maker. To remove, simply pour a little cooking oil onto
the baked-on food. Allow to stand for 5 to 10 minutes. This should
soften the food and make it easy to remove with absorbent paper
towel or a soft cloth. If the preceding measure fails to remove the
food residue, we suggest wiping the Cooking Plates with a slightly
dampened cloth and a little non-abrasive detergent."
Does this waffle makes come apart to wash? If so, how?
The manual for this waffle maker is on the www.salton.com site
3helpful
4answers
Manuel for a wm-4 belgian waffle maker
http://www.salton.com/en/service.asp
The unit has an automatic thermostat and is very simple to use. Honestly instructions aren't even really needed. You can use the link above to contact Salton to receive the information your inquiring about.
Thank you,
Lee
How do you remove the plates for cleaning?
I looked for you model by using Salton WM4 and found nothing. Is there a better model number?
Closest match was Russell Hobbs
RHBW4 and RHBW4CAN
This unit is also made by Salton
I checked several Salton user manuals and none of them had removable plates. They all stated this in the use and care guide:
Cleaning
To keep your Waffle Maker operating properly, clean regularly.
1. Unplug the Waffle Maker and allow it to cool completely before cleaning.
2. Never immerse the waffle maker in water or any other liquid.
3. Wipe the exterior with a soft, damp cloth. Dry thoroughly.
4. To remove any remaining batter on the Cooking Plates, wipe with a soft, damp cloth or absorbent paper towel. Dry thoroughly.
5. Do not use steel wool, scouring pads, or abrasive cleaners, as they will damage the finish.
Waffles sticking in a Salton wm-4.
Like Pam For Grilling, myself. Plain, melted shortening may help, too; simply spoon some on, let it melt, and brush it around.
3helpful
2answers
I need a manual for a salton waffle maker wm4
There is a site that posts PDF files of manuals for all manner of things..manualsonline.com.
Here's the link for the Salton Waffle maker, they have several versions:
http://kitchen.manualsonline.com/search.html?q=+salton+salton+waffle+maker
Does the salton waffle maker have teflon in it?
It very well may, did the box or manual say? If not and even if it did you will still need to either spay or brush with butter to keep waffles from sticking, that many surfaces with all those corners and ditches something will stick everytime unless you lightly coat with non stick something. let me know if this helps goofballlovers
Cleaning
Believe it or not but if it is a non-stick surface it can simply be brushed with cold water while the surface is still very hot. As long as you do this immediately after you remove the food. Try it with a pastry brush or similar.
33helpful
5answers
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
3/4 tsp vanilla
Top Salton Kitchen Appliances - Others Experts
Kolbrun...
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
