Bloomfield 8543.. reaches 139 degrees then cuts out. what temp should it get to? gunna put vinegar thru it tomorrow and de-scale it. got any more tips just in case?? thanx in advance,
bren
WELL THAT MEANS MY HEATING CIRCUIT IS GOOD BUT THIS UNIT DOES NOT HAVE A PUMP, IT WORKS BY TURNING THE WATER INTO STEAM AND THE STEAM RUNS THROUGH THE PIPES TO THE COFFEE GRINDES, WATER NEEDS 200 DEGREES TO BOIL.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours. Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water. If you taste vinegar..use more clean water, until the taste is ok.
Keurig does not make repair's or carries replacment parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful 3 Thumbs - Helpful
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
<br /><br />The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.<br /><br />Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.<br />Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.<br />If you taste vinegar..use more clean water, until the taste is ok.<br /><br /><br />
you should have done whats below, it may need to be done twice...last but not least..you have to put more fresh water in to remove the taste
thanx for the advice it was very helpful
