Question about Casio Watches
How to use the stop watch function - Casio Watches
  • 183 Answers
On Casio digital watches you need to cycle through the modes till you get to the chronograph (stop watch). Once there you can use the start stop button to start and stop the chronograph then use the reset button to set back to 00:00:00 when you need to start over.
Posted on Sep 17, 2009
6ya staff
SOURCE:
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
How to use the subdials on a wrist watch
One of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Oct 20, 2012 | Rolex SS/18kt Daytona
I am trying to set a digital watch, there are 4 buttons 1=light 2=mode 3=start&stop 4=lap reset. I can not find the name brand and I bought it at a second hand store for my grandson. The only name I...
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
Jun 23, 2010 | Watches
Pulled out the stop watch button on my daytona before it was prewound and the whole watch has ceased HELP
The stop watch buttons don't pull out. There are 2 pushbuttons. The upper one starts and stops the timing function and the lower button resets the timing function. The crown has three positions: 1st position is for winding, 2nd for date setting and 3d for time setting. Once things are set wind the watch in position one and it should run. If it does not take it to a watchmaker. You don't want to fool around with such a valuable watch.
Apr 22, 2010 | Rolex Daytona 116520 Wrist Watch
Is my watch authentic ? I purchased a Hamilton H77646833 Khaki X-wind Mens Watch several weeks ago and have had issues since day one. 1. The date and day function didn't work. But now it does. 2. The watch...
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 21, 2010 | Watches
What are the 3 inner dials for? How do I set them?
one of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Nov 09, 2009 | Rolex Daytona 116520 Wrist Watch
Large second hand not running, Stop Watch function?
Hey, it sounds like your watch is just fine! A nice watch to inherit.
The small second hand on the sub-dial is your normal second hand.
The large second hand is the second timer for your chronograph feature.
It should only move when you hit the side buttons. One of them (usually the top plunger/ button) will start the Chrono timer and then hitting it again will stop it. The bottom button should reset the hand to the 12 o'clock/ zero marker.
If the large hand is not functioning at all then there may be something wrong with the watch; perhaps the buttons are not making full contact within the watch or the hand may be stuck and need repair.
Hope this answers your questions. Post more questions if need be.
Congrats on your new watch.
Oct 21, 2009 | Festina Road Warrior F16273/4 Watch for...
Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Aug 05, 2009 | Watches
Setting the chronometer
They Are not settable., They just are there to replicate what the genuine looks like. The bezel is a tachamyter it is a stop watch function of the watch, but most likely your watch does not have stop watch "chrono" functionality.
Jun 25, 2008 | Rolex Ladies Daytona, 18kt WG, Special...
Watches Logo
190 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
