Our PLD4375RFC2 dishwasher fills up with water but then stops. Nothing sounds like it if even trying to come on. Presumably the next thing that is supposed to happen after the water fills up is that water is pumped around the dishwasher and the "water spouts" spin. None of this happens. It is completely dead inside the washer. The timer keeps going down, but nothing happens in the dishwasher. The water and power are both obviously working, and none of the tubes appear kinked. I think that at the end the pump does not pump the water out either. Is there some kind of fuse inside the washer that runs those things, but not the timer?
No their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
I am having the exact same problem. Except I have a model FDB221RFR2. I did as you said and found nothing in the moter. It moved freely. I put it all back together and still nothing. How hard and expensive is it to replace the moter?
