Try this.
i got my dp-301u to work fine with my hp1020 on 2 different
workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3.
once created go into the properties of the 2nd printer and change the
port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
SOURCE: reset edimax print server configuration
try to look for that tiny button around your print serverit is the resetter, it is the same with routers. does your print server comes with a cd installer, if yes install your print servers driver then you can assign your desired configuration for it.
SOURCE: Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address: 192.168.0.10
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
SOURCE: print server configuration in canon mf4150
Hi
Had exactly the same problem. Go here http://support.dlink.com/products/view.asp?productid=DPR-1260# and download the 1.24 firmware. It invalidates non US warrnty but it fixes the problem. This firmware not released in EU but just go for it. Worked for me.
Good luck.
SOURCE: I have instatalled a DP 301 print server for my HP
Yes. In most cases you can reset your D-link DP-300 series or DP-301 series print server yourself even if you don't know the password or IP. This comes in handy in situations such as when the server has made up its own password after being connected to a new router.
Cross your fingers and try the following steps...
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
5) Follow the non-intuitive instructions provided with your server to set it up again. (Note that a Quick Install Guide will likely be more useful than a manual for this step. If you have lost your Quick Install Guide then try downloading it from D-link's website, http:/www.dlink.com/default.aspx Locate your model via "product quick find" or "find your product" then click on "support resources" and look for a quick installation guide.)
Shahzad IT Department
Mitsubishi Motors KSA
