My Akura TV has inverted colour, how do I change it back
While viewing tv,after one and a half hour the colour of the screen goes blurred and changes to greenish .why is it so?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 15, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
By mistake I changed the colour of my iPad screen how do I get normal colour back
Did you invert the colors? This is under Settings > General tab > Accessiblity. Invert Color
Dec 08, 2013 | Apple iPad Tablets & eReaders
Sony Vaio colours on screen inverted and dark. I
if you are using the computer then you have to change the vga cable
Aug 02, 2013 | Sony VAIO Computers & Internet
I need tv code of "akura"
0938,0917,0933 are the codes to check with Akura brand TVs. If you wish to get more codes, http://electrohelponline.blogspot.com/ check this link. Pull up older posts there.
May 28, 2013 | Televison & Video
Akura TV, Model Number : AVL CD32700-S, Serial Number : 5974609 600288 I haven't got a manual ! Please help
I can't find anything with that model number. Perhaps you have a Akura AVLCD270-S 27" Widescreen LCD TV, in which case the manual is here.
Feb 12, 2012 | Televison & Video
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Thin coloured lines running down center of tv. Panasonic Viera.
HOPE THIS WILL HELP TO SOLVE THE PROBLEM.....
Aug 07, 2011 | Panasonic Televison & Video
My akura tv remote stopped working so i bought a universal remote but i cant get this to work either
Hi Peter, we would need more info....
Model # of the TV
Are the akura codes not available for the remote?
If available is it that none of them work?
Jun 09, 2011 | Televison & Video
The audio works fine but no video
make sure that your video rca plug is plugged into the back of your tv and in your source,they are colour coded...
Jul 13, 2009 | Toshiba 14DLV75 14 in. TV/DVD Combo
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
