Question about GE Microwave Ovens
GE microwave (mfg'd. 2010) display says, keypad shorted, may need service
    Top Expert:
  • GE Master
  • 10,535 Answers
Hi Meloday Waldo, indicates microwave model you are commenting on, to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Meloday Waldo, indica modelo microondas del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Posted on Oct 10, 2019
6ya staff
SOURCE:
caroldon
  • 17130 Answers
SOURCE: My ge microwave displays a message " keypad has
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.Some dirt can accumulate and cause the tracks to short resulting in this display. Try to use heater to warm off any moisture.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Posted on Jul 25, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: My ge jvm1540 over the range microwave is
see this steps and follow and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can b
Posted on Nov 16, 2012
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Posted on Dec 14, 2012
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Ge spacemaker microwave oven
you must open the keypad, disconnect the microwaves, and disconnect all connector, specially from the ribbon or plastic very carefully, use pencil erase and clean it from corrosidon and dirty, the contact clean it contact solver or use alcohol isopropyl to 100% and fix it.
Posted on Jul 10, 2013
th7593961
Terry
SOURCE: My GE microwave has a Keypad short. Do I have to replace the entire control panel?
My microwave (JVM1540DN1WW) turned itself on (apparently with the "1" express button), then self-diagnosed a keypad short and shut down except for a persistent beeping reminder. This happens mostly randomly, but more so when there is heat or steam rising from the stovetop below.
I unplugged the keypad membrane from its socket on the controller PCB (i.e. unplugged the whole unit, pulled off the front assembly, unplugged the membrane's flex tail, put the assembly back on with the membrane disconnected, then plugged the unit back in). Since the controller no longer detected a fault without the membrane connected, the fault appears to be with the resistive button membrane and not with the controller PCB.
The keypad membrane is hard to find as separately from the expensive assembly that includes the controller PCB, the display, and the right front trim panel. It's also really hard to separate the from the trim panel without either heating it to soften the adhesive or freezing it to make the adhesive brittle.
Fortunately for mine, the short was in the flexible circuit's exposed tail that extends from the membrane to plug into the controller PCB. The flex circuit appears to be soft PET, printed with both carbon and silver inks. It's printed on one layer, with the tail folded ink-side-inward to reach both (i.e. row and column) sides of the button array. When folded, traces 9 and 16 nearly touch, and those are the pair that cross at the "1" button. When bent around the metal chassis of the trim panel, these must make contact through their worn or porous surface insulation.
Adding a thin piece of insulating plastic between the opposing sides of the flex tail avoid the false presses of the "1" button.
Posted on Jul 02, 2015
My ge is Microwave beeping and says keypad short may need service
PCM/Smart board (comes with the keypad), If it is less that 30 days beyound the 12 month warranty call GE and ask for a "good will concession" ... 1800-GECARES
Apr 28, 2014 | GE XL1800 1100 Watts Microwave Oven
Keypad shorted may need service
You'll need to carefully removed the keypad assembly and look for moisture etc.
Nov 29, 2017 | GE JVM1740DM Microwave Oven
Jul 10, 2013 | Microwave Ovens
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
My GE microwave is beeping and the display says F3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
We would need your model number to give you more specific info, part ordering info, and en estimate if needed.
Simply contact me here with your model number and symptoms for free help.
On some models, the membrane keypad is peeled off and a new one stuck on.
In other models, the plastic frame must be replaced, and it comes with a keypad already installed.
May 12, 2011 | General Electric Microwave Oven
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
Jul 26, 2010 | GE JVM1850 1000 Watts Microwave Oven
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
