Question about Whirlpool Washing Machines
How do I cancel wash cycle on my Whirlpool front loading washer
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: whirlpool washer F22
thats a door lock failure code try unplugging the washer then let me know shut the door firmley before operating
Posted on Mar 28, 2008
Anonymous
  • 750 Answers
SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
Posted on Sep 23, 2008
Anonymous
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
Anonymous
  • 294 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Posted on Apr 06, 2009
Anonymous
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
Whirlpool Duet front load Washer Model WFW72HEDW error code E1/F3 will not drain or unlock
Unplug for 5 minutes then plug back in. This may reset code. You may have to push cancel / pause button for 3-5 seconds. If this doesn’t help, drain pump may have something obstructing it or may be defective
Oct 06, 2018 | Whirlpool Washing Machines
Whirlpool front load washer won't cancel cycle/unlock door
You may have a problem with either your drive motor, motor control unit or main computer board (known as a CCU).
PS Check for the obvious first. Make sure the drive belt is still attached and not broken before getting too deep into troubleshooting everything else. NOTE: More commonly, this is an indication of a motor control unit failure.
Aug 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet front load washer
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front Load washer won't start
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
Mar 03, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
