Question about Panasonic Lands Phones
I can receive calls but cannot call out. I get a busy signal to all calls I try to make. I have a Panasonic 60 Plus. Can you hwlp me
6ya staff
SOURCE:
Anonymous
  • 1463 Answers
SOURCE: We cannot receive or send faxes
hello dmhertz
anything here that may help Canon .
riz.
Posted on May 12, 2008
Anonymous
SOURCE: no dial tone/ others trying to call get busy signal
Turns out that it was a wiring issue and not the phine.
Posted on Jun 20, 2009
Anonymous
SOURCE: Phone: Samsung Propel Problem: I
Mine also did this. It only does this when you do not have signal. If you do have signal and it still does this you just need to call ATT and confirm it with them. They ended up sending me a new one that has better software on it for free.
Posted on Sep 20, 2009
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: my house phone always gets a busy signal when calling blackberry
you will need to take this up with your carrier it does sound strange...maybe you could try entering the area code before dialing the cell number.
Posted on Feb 06, 2010
  • 102366 Answers
SOURCE: Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Posted on Apr 10, 2012
Testimonial: "Thank you. Looks like it is a new feature with my voip company, usualy they send an email. After I deleted all the old messages everything went back to normal."
Caller says my phone rings 2 x's and then the busy signal. I don't know how to fix this.
For purposes of discussion, lets say you are the caller. The "busy" signal may be a "reorder" signal. A reorder signal indicates that that the network inbetween your network and the recipient's network (or just the recipient's network) can not "find" a route back to your network. If you had received a busy signal, you reached the recipient's network but the recipient was on another call. If the problem is a "trunk" failure, the solution is beyond your reach. If it is a line failure, a call to the phone compan
Aug 07, 2017 | Lands Phones
Panasonic KX - TG5664
may be the problem is with the speakers check that first
Jun 02, 2008 | Lands Phones
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Panasonic KX- TGA652 busy message
If you get a busy signal when you pick up your second phone to participate in a call in progress, make sure privacy mode is set to off. Enter the menu, then scroll to initial setting, then scroll to privacy mode, set to off, then click save. You can also go directly there by entering menu, then #194, set privacy mode to off, and save. Make sure to do this on all handsets connected to the line.
Oct 26, 2012 | Panasonic Lands Phones
Apr 10, 2012 | Panasonic Lands Phones
KX-TG6441 Phone shows "in
You have a short circuit somewhere...start by unplugging the phone from the phone jack in the wall. Wait 15 minutes or so for the line to clear, then try calling your number from another phone. If you hear a ring, the problem is either in your phone internally, or the cord connecting the phone to the jack (which can be replaced at Radio Shack or similar). BTW, are there other phones in the house? If so, do the same with them one at a time to isolate the problem. If disconnecting all phones (and waiting) doesn't clear the problem you have a short elsewhere, such as house wiring, or the phone jacks. But a busy signal ALWAYS indicates a short... good luck.
May 31, 2011 | Panasonic Lands Phones
Panasonic KX-TGA101 not working
By jim_giardine on Jan 03, 2010
My parents have had their Panasonic KX-TGA101 for a little over a year and it just stopped working. It no longer rings when a call comes in. Plus when we try to answer a call or place a call all we get is a busy signal both auditory and in the display window.
SOLUTION: you might want to change a new phone line, that's maybe the culprit, most of the time is the phone line is worn out first due to too many reasons.
Jan 03, 2010 | Panasonic KX-TGA101S Cordless Handset
I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
Apr 10, 2009 | Panasonic KX-TA824PK Phone
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
Continuous Fast Busy Signal
Your modem/fax board is most likely bad. there is a relay on that board that has probably failed. It is stuck. I doubt it can be made to work. those are really small relays on those boards.
Jul 07, 2008 | Panasonic PANAFAX UF-6000 Fax
Lands Phones Logo
64 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
