In some old model av-amp, if the sampling freq. is 96KHz or
above, av-amp confines its playback in 2 channels only.
Check the sampling input source is 96KHz or not.
Or perform this test
(1)Download htr6130 service.
(2)Start the self-diag test
(3)follow the instructions written on p.25 to 33 to do the tests.
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
SOURCE: HTR-6130 will not turn on
Hi
Does the receiver have a switch that allows you to turn off all the speakers?
If so,turn them off and see if the problem stays.
If it still kicks off then , one of the power amp outputs has failed and it will require some fixing
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
SOURCE: how to hook up a xbox 360 console to my yamaha 6130 receiver
You will need an additional HDMI cord...you can get them without getting ripped off by purchasing at bluejeanscable.com.
Connect your HDMI out from the xbox to the receiver. Connect the additional HDMI cable to the "out" HDMI connection on the receiver and connect the other end of it to your TV.
SOURCE: yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
