Question about Fossil Watches
I have a Fossil ME9034, I replaced battery that was in it (396) but watch ran slow. Would it be a 371 and would that make it run on time ...thanks
6ya staff
SOURCE:
Laurea McLeon
  • 14 Answers
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
Anonymous
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Posted on Nov 09, 2008
Anonymous
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
Anonymous
SOURCE: What's the replacement battery# for the Luminox 3000 Navy watch?
I was shopping for one in Thailand and it was a GE 371. I did not replace it because they only carried the cheap china battery's.
Posted on Apr 18, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
I have a fossil ES-1355 watch and it running slow. I installed a new battery and still running slow. Is there an adjustment I can make.
most batteries that run of a battery are controlled by a frequency crystal or electronic setting and is not adjustable
however take it to a watchmaker or jeweller as it may be adjustable using their instruments
May 15, 2016 | Fossil Watches
What type of battery doews the fossil am-3734 use
I CALLED FOSSIL AND THEY WERE SO NIUCE AND POLITE ON SATURDAY EVEN THE BATTERY IS 371
Jul 22, 2012 | Fossil Watches
I have a big tic fossil watch. The flashing second is working properly, but the hand doesnt. It looks like slowing down. How can I fix this problem. Thank you
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
Aug 01, 2011 | Fossil Big Tic JR7896 Watch
What size battery and how do you change it?
most fossiles are 371, 377 or 364. fossil backs can be hard to get back on so u might want to take it to a jewelry store its only like tem dollars
Oct 10, 2009 | Fossil ES9382 Wrist Watch
TRYING TO SET THE TIME ON A FOSSIL WATCH. ITS DIGITAL WITH LIKE A STOPWATCH APPEARANCE DQ-1147 (900509) IS ON THE BACK OF THE WATCH
I called the local Fossil Outlet in Lancaster, PA and got them to explain how to change the time. By phone they are 717 396-0823
There are four buttons on the watch.
Press the set-el botton once followed by the mode button once and this will put you into the condition to make adjustments. Each time you press the mode button a different adjustment can be made....so you go from hour to minute and so on
Once you get to the adjustment you want to make you use the right two buttons to increase or decrease the setting
Jul 26, 2008 | Fossil Watches
Fossil AM-3662
It has a silver cell button battery, type 371 or equivalent.
Dec 10, 2007 | Fossil Watches
Watches Logo
50 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
Ray Murphy
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
