Question about Sony Televison & Video
I have a Sony KDL-60W630B tv that has 6 blinking red lights on start-up. I replaced the T-Conn board but still getting the 6 blinking lights.
Sony's trouble shooting chart suggests LCD panel. Before I start replacing more parts looking for any suggestions. Thank you Bob
6ya staff
SOURCE:
C-Dog
Carl Manaloto
  • 84 Answers
SOURCE: 6 red light blinks-possible thermal fuse prob.
You need the location of the part that's stamped on the board near where it was soldered in. And you need a soldering tool to resolder the new part in and cut the excess wire with cutters so you're not to short out the circuit.
C-Dog
Posted on Feb 10, 2008
Vista Electronics
  • 1694 Answers
SOURCE: tv blinks 6 red blinks
Thermal Fuse kit needs replacement = part # 1-910-023-93
Qualified tech only.....T.
Posted on Jun 27, 2008
Anthony Gonzales
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
Anonymous
  • 187 Answers
SOURCE: Looking for the part number for the table top
you need your model number and product code, you can find those numbers in the back of the TV, next to the serial numbers.
With this numbers you can order any part for your TV (dont need any other)
Posted on Jul 08, 2009
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: Sony lcd tv model KDL-40S2000
That is almost always an indication of main-board failure on these Bravia LCD's. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Let me know if you want me to try and track down the part for you, but please make sure you think you are capable of doing the repair.
Thanks
Tim
Posted on Oct 06, 2010
I have replaced the main board on my Sony kdl-60W630B but it still does not work. When I plug it in the red light blinks 5 times but the TV does not not come on
I would try contact tvpartsguy.com as they are really good about diagnosing and helping find the right part for their tv.
Nov 22, 2017 | Sony Televison & Video
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
When I turn on my sony KDL-52W5100, its acting like its booting up (showing the sony and bravia)then the screen goes blank. Then the red light start blinking 6 time. what do I do/
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
Dec 29, 2014 | Sony KDL-52W5100 TV
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
