Contact the software maker
[email protected]
or buy a copy that has window 10 compatibility
at
https://www.smartkidssoftware.com/nddav39.htm
you might be able to emulate the operating system to be compatible with an emulator windows 95 most likely
Try the compatibility troubleshooter under windows settings. You should be able to run the program for the version of windows that supported the original release.
SOURCE: i want insall sound driver for windows xp profesional
Try to install this Sound Driver.Click on the link Downlo/Install/Restart it Should Before installing the new driver Make Sure the old driver is removed
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-45941-1&lc=en&dlc=en&cc=us&product=3177516&os=228&lang=en
SOURCE: I have a quickCam Pro 9000. I tried installing it
HI,
Logitech has released new cam drivers for windows 7.Please click on the below link to download it.Once you click on the below link just click on run.After it is finished downloading just follow the onscreen instructions to install the drivers for windows 7.
http://www.logitech.com/pub/techsupport/quickcam/lws110.exe
Thank You for using fixya
SOURCE: Having trouble installing Orbit AF drivers into Windows 7 Pro Ed.
you should use the cd to download it i bet itll work
-a person
peace love and robert pattinson
SOURCE: Compatibility of Treasure Math Storm with Windows 7
It might not be necessary- I'm assuming that you've installed it and it doesn't work.
If you right-click on the icon that launches the program and select Properties, you will be taken to a box with lots of options; one of which is "Compatibility".
Tick the "Run this program in compatibility mode for:" box; then in the dropdown list select an operating system that you know the program does work with. Start with XP and work backwards to older OS versions if that doesn't work.
Hope that helps.
