Question about Toys
Fisher fbx 1262 want charge it just cutoff and want charg
    Top Expert:
  • 64,797 Answers
DEFUNCT BATTERY POSSIBLY
Posted on Oct 07, 2019
6ya staff
SOURCE:
Where does the charger plug in
you need remove the battery from his foot and charge it outside the toy.
manual:
http://www.fisher-price.com/inst_sheets/T2742a-0920.pdf
Those batteries can get hot when charging - so best leave it dangling if possible so it wont damage anything.
Nov 10, 2013 | Mattel Fisher-Price Imaginext Big Foot
We have a power wheels Mercedes and have charged it but it won't start
check the battery with a multimeter and make sure it is showing at least 12 volts
Jan 01, 2013 | Fisher Price Fisher Power wheels Cadillac...
How long do you charge battery after you've done initial charge
a good rule of thumb is one hour for every amp hour that the battery is, so if its a 12ah battery then charge it for 12 hours
Jul 14, 2012 | Fisher Price Fisher Power wheels Cadillac...
Charging a fisher price power wheels
nope, way to many amps, could cause it to explode, you can get a replacement charger off of ebay for about $6 delivered
Apr 29, 2012 | Fisher Price Fisher Power Wheels Jeep...
Fisher Paykel washer keeps saying cutoff restart
The power supply is faulty in the motor controller.
Replace motor controller with new/Reconditioned board.
Apr 25, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
The ac compressor clutch does stay on
Hello narto7
If you replaced the compressor yourself and tried to charge the system with those booster cans from the parts store, then air and moisture remained in the system. This will prevent you from getting the correct
charge and the correct pressure in the system. This can cause the lowpressure cutoff (on the accumulator right side of firewall) or depending on how much R134 was put in) the high pressure cutoff (on the compressor) to cut power to the compressor clutch assy. If this is
the case, have the system evacuated and charged with the proper
equipment and that should clear it up. However if it was charged properly, check the 2 cutoff switch's I mentioned. There should be power in and power out on both with the a/c on. There is also a relay
for the a/c you can check. But due to the split year in 95 it's located in
1 of 2 places, in the fuse relay block under the hood or under the right
side of the dash above the glove box. Remove the box for easier access. Hope this helps
Jul 06, 2010 | 1995 Chevrolet Suburban
My Scooter (Fisher & Paykel - Columbus) Will not charge
Hi. These machines will not charge themselves if the batteries are too flat. The charging system is run by the micro processor IC in the scooter. If the battery voltage is too low the the IC will not have enough voltage to operate.
Remove the batteries from the machine and charge in parallel on a 12 volt charger. Once they are charged, put them back in the machine, and try the scooter on charge again.
Good luck. Neil.
May 15, 2010 | Health & Beauty
Batteries are finished. Replace them with fresh ... battery life is about 2 years.
Mar 28, 2010 | Health & Beauty
Toys Logo
41 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
