What is it that you are losing ? You can set the power level by using the marked touchpads on the touchpanel, much like setting the volume on a TV. If you do not change the power setting and it is taking a long time to heat things or intermittently fails to, that is usually a sign that the Magnetron has reached its use by date and needs to be replaced. Not always an economical proposition unfortunately as spare parts are often exorbitantly priced.
Before removing the cover of the oven in attempt to carry out any maintenance such as replacing the Oven cavity lamp, make sure the oven is disconnected from the power point ! The voltages in a microwave oven ARE LETHAL !
SOURCE: Will not heat.
Hi I've been out of the microwave repair business for a few years now, but the technology has remained virtually the same as far as I know. You obviously have some knowledge of them, as you know about the safety switches in the door. Microwave ovens are actually a very simple device, to test it, put a coffee cup of water inside, and set the unit on high for one minute. A second or two after you hit the start button, you should hear a fairly loud "bong" noise, and a hum that continues untill the time runs out. That noise is the magnetron starting up, and if that noise does not happen, then the magnetron or related circuitry is probably bad. NEVER open up the oven, as the magnetron may be charged, and must be discharged by a technician. If the sounds that I described are present, then the water should be boiling or close to it in one minute, if not,then something I've never seen has gone wrong. Assuming you had a year warranty on it, I know from experience that if you contact Goldstar customer service by phone, or letter, they will often extend their warranty a month or so to keep happy customers. Its worth a try. Hope this helps you out. P.S. Never operate a microwave without something inside (Non metalic)
SOURCE: GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
SOURCE: Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If
for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Testimonial: "Excellent. Thanks so much for your very quick and valued help! Will do as you suggest and give further feed back on outcome. Again, Many Thanks. "
