Question about Bosch Dishwashers
I mistakingly put the blue cyphon the wrong way around in the detergent dispenser drawer after cleaning and closed the drawer shut. Now the drawer will not open. How can we get it out?
Bosch model WAN28002GB/23
6ya staff
SOURCE:
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: DETERGENT DISPENSER
Hi the plates and bowels should face into the center of the dishwasher, the spray arm spins at the top and bottom from and sprays outward, check that you are using the soap dispenser and not the rince agent cups, also check to make sure it will spring open , ifall that is good then you may have a bad wax motor or a loose conection. at the wax motor. let me know
Posted on Aug 30, 2007
Anonymous
  • 76 Answers
SOURCE: Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Posted on Nov 18, 2007
Anonymous
  • 1665 Answers
SOURCE: detergent dispenser stuck, I think the detergent cup is preventing the drawer from opening
Here there is a user guide and instructions of a similar washer model.
http://www.laundrymanuals.com/manuals/mfg/lg/wm2496h.html
and also all available LG washer manuals to download.
http://www.laundrymanuals.com/manuals/mfg/lg/lg_frontload_washer_product_list.html
Have a look of how top lid is mounted.
Posted on Feb 15, 2008
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
Anonymous
  • 86 Answers
SOURCE: tablet drawer,dispenser wont open at all
Hi, well you we need to check the ribbon cable in the door lining to make sure that none of the cables have been broken with the movement of the door. If they are fine then you should replace the dispenser unit if you are getting 240v to the dispenser solinoid.
Get back if you have further problems...................?
Posted on Mar 07, 2009
Detergent doesn't dispense from the drawer
Remove the drawer and clean it thoroughly, also clean the drawer area of any detergent residue. Check that there is water flow into the drawer from the inlet nozzles above it.
Make sure you are putting the detergent in the correct drawer compartment. If it still persists further investigation of the feed in and out pipes will be required..
Apr 17, 2017 | Washing Machines
Liquid detergent won't dispense properly.
Pull out the dispenser drawer as much as you freely can. There is a tab that you can depress to pull the drawer out completely. You can then rinse it completely with hot water to ensure it is not clogged.
Mar 06, 2015 | Washing Machines
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
Front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Mar 26, 2009 | LG WD-16115FD Front Load Washer
Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Feb 03, 2009 | Washing Machines
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 11, 2008 | LG WM-2277HW Front Load Washer
Detergent and fabric softener dispense at the same time
Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking out of detergent dispenser- big time
Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
Aug 24, 2007 | Haier XQG50-11 Front Load Washer / Dryer
Dishwashers Logo
51 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
