HP Media Center m7250n (ED842AA) PC Desktop Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp cpus power supply green light constantly blinking
I have hp cpu.It was really working very well untill today.But suddenly when i turned on power supply switch green light constantly start blinking.At the same time my monitor is blank nothing on screen.So please give me some guidance regarding this matter.thx in advance.
  • Anonymous May 11, 2010
    any changes to the insides? Did you open it up to do some cleaning etc.?
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on Sep 17, 2009
Anonymous
Expert
Level 2:
Answers
55
Questions
0
Helped
22930
Points
161
As always verify all cords are plugged in properly. After that it sounds like you power supply went out. It is not that hard to replace. Make sure you unplug power cord. After you remove the pc cover, Usually you just need to unscrew 4 screws for the power supply. Somewhere on the power supply it should say how much watts it is. Anywhere from 200 watts and up. Just replace with exact wattage.
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Power supply LED (Green) turned to red and blinking and nothing works
Power Supply is bad. Plain and Simple. Replace it. Regards, joecoolvette
HP a1050y no power I tried all suggestions posted, and everything
Try Unpluging the power supply and press and hold the power button for about ten secs - leave it off for about two min and plug it back in and turn the computer on.
see if that work,
Thanks
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Won't turn on blinking red where green power lights should be.
plase open the cpu & plug in the ram in the right order.
D530s will not power up, odd blinking green LED on mobo
Ok, this is acting as if your MB is getting power but doing nothing with it. This very well could be a MB problem where something (unknown without looking at it) is fried. Just for grins, take the cmos battery out and let the pc sit for 1/2 to 1 hr before putting it back. If this does not work, I would contact HP for a replacement MB.
System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
