Question about Music
No signal on aux 1 on mix wizard wz3
No signal on aux1 on mix wizard wz3
I'm using 2 different power amps and the monitor (M) will not work unless I have the L=R sliders up or I can put the M send in the R and it will work the monitors separately. Why and what am I doing w
1st....the output section, "M" stands for mono. The A&E does not have "monitor" sends per say but instead calls them "Aux's." Adjust the proper Aux for the input channel 1-16 and use the Aux output section (row of knobs above output sliders) as the master volume. By using Aux 1-4 (and with more amps) you could send 4 discrete monitor mixes to four different band members. Bass likes his monitor strong but doesn't want to hear other members while guitarists want to hear only himself and the singing drummer...etc.
May 30, 2014 | Allen & Heath Mix Wizard Wz3 16:2...
HOW DO I RUN A MONITOR THROUGHT THE BEHRINGER MX1804X?
If you're trying to get a monitor feed from this unit, use the "aux" send. Connect the "aux send" to your monitor amp. The main Aux fader provides "master" level and the "aux" knob for each channel allow you to "mix" your monitor signal.
Oct 22, 2013 | Music
Hi i have an Allen and Heath ZED 22 with no onboard effects. I would like to use an external Behringher unit but am having difficulty in connecting the processed signal back to the mixer. i would like to...
Send audio from board via the "Aux1 Out" to the input of the effects unit. Now connect the output of the effects unit to "ST1" and control the amount of effects to each channel via each channels "Aux1" control. Adjust the Aux1 controls in the output stage (controls on the right side) for proper levels.
Older boards called this connection "effects send" for the output to the effect, and "effects return" for the effects out back to the board. The better choice was to use "effects send" into the effect but connect the effects output to an unused channel on the board. Using this scenario allowed EQ adjustments to be made before mixing it out to the amps and speakers.
Oct 01, 2013 | Peavey XR 8600D Powered Mixer
Does Allen-Heath Mix Wizard 16:2 (first generation) require Tip-Ring-Sleeve for Aux sends?
You should use TRS since that is balanced just like XLRs.
Especially for long wire runs. This is if you go for XLR on the other end =
Pin 1= Sleeve
Pin 2= Tip (HOT)
Pin 3= Ring
Normally, in US equipment, 2 & 3 are inverted (3 is HOT), but you got British here, they switch the HOT pin on the XLR to pin 2.
That means that if you run this unit with US speakers your signal will be out of phase. Be careful there... I have lived this with AH boards before.
You can also use normal unbalanced cable for short runs, but I suggest keeping to standards.
Dec 10, 2017 | Music
I have a Behringer sx2442fx mixer,and when i try to use my aux 1 and 2 channels for monitors it doesn't seem to be working. I sthere a chance that i have a button or something on the board thtas p
Make sure that you have enable the main monitor volume at the end of the mixer. They are labeled AUX1 and AUX2 as well located under the last channel of the mixer. If those are on 0 your monitors won't work
Jan 19, 2012 | Behringer Sx2442fx Eurodesk 24channel...
I'm trying to plug an active speaker into aux 3 for a third monitor mix but it doesn't work (I do the same with aux 1 and 2). Am I missing something? Cheers,
I answered another post of this earlier. The AUX3 is strictly POST FADER... you MUST turn the channel sliding fader up to send signal to AUX 3. Also the AUX3 channel gain KNOB must be turned up. Also the AUX master gain KNOB must be turned up. Make sure your cablles are balanced TRS cables from the mixer to the powered speakers.
Sep 02, 2011 | Soundcraft FX16ii 16Channel Audio Mixer
I am unable to send a signal via aux 6 from a channel to ONLY the K sub. The only way I get signal is if I raise the channel fader but then the signal goes to the house L/R mains as well. How do I send a...
It appears that AUX6 is default factory strapped as POST FADER. If you want to change that you will have to disconnect jumper L to A for all channels you want the AUX to be pre-fader and instead connect K to S for the option jumpers. I don't know if this requires soldering or whether they are push on jumpers. These should be available in the back cover. In ADDITION you will have to run the switched pre/post fader switch in the PRE position which will make ALL AUX's that are strapped this way PRE FADER.
Jul 09, 2011 | Allen & Heath Mix Wizard Wz3 16:2...
How do you control volume for a specific instrement in a sub group being used as a moniter mix with out afecting the main mix
Send the signal to the subgroup via and Aux channel PREFADER. This will allow you discrete volume control over your monitor mix.
Jan 06, 2011 | Behringer XENYX 2442FX Mixer
I have a Peavey FX 16, im trying to hook up a monitor so my guitar player can only hear himself. Im running 2 amps for monitors, 3 of us work off of 1 amp for our monitors and we run him one his own amp....
Quick and dirty way is to turn up one of the AUX channels, say #1 on the Guitar player's inoput channel/strip. Have all other AUX #1 completely CCW so none of the others get mixed on the AUX.
Use a TRS cable from AUX1 output to the guitar players monitor amp.
NOTE. The signal to his amp will only be controlled by the AUX1 on his channel AND the AUX1 Master.
One normally uses the AUX outputs for monitor functions.
Jul 19, 2010 | Peavey 32fx USB 32 Channel Mixer
Music Logo
60 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
