Washing Machines Logo
r
robert andrew lockhart Posted on Oct 06, 2019
I have a bosch serie 6 washing machine with a flashing key symbil and i can not open door its has a touch screen control pad what do i do
vkc26298
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 06, 2019
vkc26298
Contributor
Level 1:
Answers
Questions
0
Helped
256
Points
I get paid over $180 per hour working from home with 2 kids at home. I just got ypaid $ 8550 in my previous month It Sounds unbelievable but you wont forgive ourself if you don't check it..... http://www.Geosalary.com
5 Related Answers
Anonymous
  • Posted on Feb 21, 2010
SOURCE: i have a bosch classixx 6 1400 express washing
Hold the start button in for 3-5 seconds and it should release it.
Anonymous
  • 1382 Answers
  • Posted on May 19, 2010
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
prem mathew
  • 662 Answers
  • Posted on Jun 14, 2010
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
prem mathew
  • 662 Answers
SOURCE: key symbol showing
prem mathew
  • 662 Answers
  • Posted on Jun 17, 2010
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Bosch Serie 6 Exclusiv won't start washing, door light flashing even after door lock replacement.
please verify with the product documentation that the flashing-door symbol indicates what you've initially mentioned. Apart from that, you might look for the sensor and hold it in to temporarily overcome the issue. If the door being shut is the issue, pressing in the sensor should fix the issue for you temporarily. If not, then you can work with Bosch or Home Deport to moving forward.
Prior to their arrival, you can power cycle your machine 1 or 2 times and check for the door symbol once more. It could be that they sensor has gone bad for some reason.
Thank you
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
2answers
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Bosch washing machine classix 6 Stopped working. wont let me program it. A key symbol flashes on
I believe that the key symbool indicates that the machine cannot lock the door. Sometimes the result of a slightly sticking door interlock mechanism. Open the door and close it hard and firmly (slam it a bit, but don't get silly about it!). A good test to see if this is the problem is to attempt a program with the door swinging open. If the symptoms (flashing key) are the same, then the issue is almost certainly narrowed down to that door lock mechanism.
If this fails, unplug the machine from the main power source and leave it for 20 minutes to allow it to reset its self, then try again.
2helpful
2answers
Settings wont change
3helpful
My Bosch washing machine door will not open and it keeps flashing " check door" however there is no child lock on and also no clothes stuck in door. Also I have detergent and bleach in the tray and do...
Check out this link to the Bosch service manual for more information regarding your machine: http://www.bshextranet.com/files/techtoolbox/WFMC1001UC_9000151579.pdf
This may offer some help...if this is of no use then us the associated info to contact the mfg directly for more info. Thanks, Randy
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
