SOURCE: Pioneer DEH-P3000IB... Hook up RCA
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
SOURCE: Pioneer AVIC-Z2 won't display dvd on rear screen
Hello [1] Touch [Settings] in the navigation menu,
The settings for your device has some trouble I thinks. Please set it to its Factory Settings and ckeck. To reset it to Factory Settings:
then touch [Restore Factory Settings].
[2] Touch [Yes] to clear the current setting
OK.
SOURCE: I've got a vsx-920-k Pioneer
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
