Question about Kenmore Cooktops
Old kenmore cooktop right side quit
Checked fuses by switching them around but right side won't light up or heat up
6ya staff
SOURCE:
Anonymous
  • 288 Answers
SOURCE: solid cooktop elements not heating,tripping breaker switch in panel box,w&w/o cartridges
By cartriges do you mean the sockets that the element plug into? If so when one of these burn out it will cause these type of problems.
Posted on Jan 15, 2008
todd in nove
SOURCE: Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Posted on Aug 13, 2008
Anonymous
  • 135 Answers
SOURCE: Our downdraft fan switch broke
There is no fuse on the unit. I suspect your house circuit is blown. If not, then a wire may have burnt off. Hope this helps!
Posted on Jan 01, 2009
jackiaria
Jack Iaria
  • 350 Answers
SOURCE: Drivers heated seat won' work
Probably a fuse!
Under the dash on the drivers side or under the hood.
New cars have them labeled right at the fuses not in the manual!
Hope this is helpful.
Good Luck!
Posted on Jan 22, 2009
Anonymous
  • 4 Answers
SOURCE: driver heated seat not working
Check you connections both under the seat and at the switch. Many times corrosion will occur due to the amount of amperage that goes through the circuit.
Posted on Jan 30, 2009
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
Two burners on right side do not heat
Check fuses. Burners are usually fused in pairs. Probably 2 fuses since 220V.(one for each 110 side of feed).
Mar 01, 2014 | Kenmore Cooktops
Regulating the heat on Kenmore cooktop.
Bad control or infinite switch. replace the switch for that element and you will be good to go.
Jul 05, 2010 | Kenmore 36 in.43492 / 43494 / 43499...
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Oct 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
63 people viewed this question
Top Kenmore Cooktops Experts
mcgsp
Level 1 Expert
jdthefixer
Andrew Taylor
Andrew Taylor
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
