SOURCE: Quattro Plus heater will not stay alight
Does this unit have a thermocoupling?
If so replace it. (6 bucks)
It is the units flame sensor and they routinely go bad.
When they no longer sense flame the unit will shut off gas to the ignitor/burner.
It will only stay lit when you are manualy holding the button.
SOURCE: Oven will not respond
try pressing the oven regulator knob for a while 3 to 5 seconds on ignition its a safty thing so kids cannot gas themselves all cookers have them. you have to hold it in.
SOURCE: my rangemaster cooker lights on ignition but only
It will most likely be the thermostat that is faulty and will neeed replacing. If it wwas the safety device then you would not get any gas at all.
SOURCE: How do you set the correct time on the rangemaster
Press in either the first and second buttons on your timer (newer types) or the second and third buttons (older types) and while holding them in press the plus or minus buttons to set the time.
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me [email protected]
