If you're trying to put an equaliser in between a source and an preamp or integrated amp, the amp needs to have tape OUT or dubbing OUT connections. This will go to the eq's IN. Then eq OUTs should be connected to the tape or dubbing IN on the amp. When playing any source you set the amp's source selector to tape or dubbing IN and now what you are hearing is coming through the equaliser.
SOURCE: Installing RCA outputs on an EQ.
You can, but first touch the 2 speaker wires to the RCA connections on the circuit board and see if sound comes out. IF so, then solder in 2 RCA jacks
SOURCE: Need help connecting my eq to my system.
You will want to connect all of your devices to the pre-amp or receiver, then connect the outputs of your pre-amp/receiver to the inputs of the EQ. Then connect the outputs of the EQ to the inputs on the amplifier or receiver. If you give me some model numbers, I would be able to tell you exactly which cables go where.
SOURCE: Connections on back of EQ are input and output and
The tape out go to the EQ input and the tape in go to the EQ output!
SOURCE: hi i trying to figure
Without having the exact model numbers of all your Pioneer deck and your Clarion EQ, what I can do for you is send you to the following website:
http://www.ehow.com/how_7207112_wire-car-equalizer.html
Once you get to the page scroll down to the link called AudioControl: EQX Owner's Manual. Download that pdf file. It is actually the owners manual to an EQX equalizer. If you then look at page 10 and 11 they show you a wiring diagram that will probably fit what you are looking for. Essentially what you are going to do is the following:
1) Wire the main output of your deck to the Epicenter unit.
2) Wire the Epicenter main outs to the Balanced Input of your Clarion EQ.
3) Run the Highpass connections from the Clarion EQ to your Tweeter amplifier, and then wire the amps output to your Tweeters.
4) Run the Lowpass connections from the Clarion EQ to your Subwoofers amplifier, and then wire the amps output to your Subwoofer. If you have two separate amps for two separate subs then wire accordingly.
5) If you are going to use your 4 channel amp to run your tweeters and your midrange speakers, then you would run the full range output of your EQ to the two channels of the amp that would be your main or midrange speakers. Then you would run the Highpass outputs of your EQ to the 2 channels of the amp for your tweeters, and then the ouput of those two channels would go to your tweeter speakers.
This should give you the necessary information to wire up all of your components. IF you need any further information then please don't hesitate to let me know.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
SOURCE: hi i trying to figure out how to wire up my rca's
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
