SOURCE: Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
SOURCE: kenmore 600 series dryer, does
check (if it is gas)power atthe igniter....If there is and it doesnt glow when you start dryer ...Replace the Igniter.....2nd. ..If you
have no power at the igniter ....replace the Thermal fuse (see picture above)
SOURCE: have a kenmore model 110.64962300
Before you begin, UNPLUG DRYER.
Remove bottom access panel by using a putty knife to depress panel clips (item 46).
Check the High limit fuse and heater for continuity. Heater (item 14) <20 ohms and HI-limit (item 47) <0.3 ohms.
If the heater or HI-Limit has failed it may be that the exhaust airflow has become blocked or restricted. Check the hose in the back ofthe machine for crushed hose. If OK, the vent pipe may need cleaning...check out www.linteater.com for vent cleaning info.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
SOURCE: Kenmore Electric Dryer 110.62922100/Runs but no heat
remove the lower front panel. the element is right there with all the access screws and wires. check the thermo relay also known to go bad..................
