Sony DCR-HC32E DV Digital Camcorder Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony hc-32 touch screen won't work
The LCD panel works but the touch screen does not. You can ff,play,
rev, etc. using the remote. You cannot access any menus or set the date
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Sep 16, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957447
Points
33084
When touch switches become nonworking then mostly its cause of connecting flexible ribbon wires between LCD board and camcorder main board that got cracked so touch buttons signal does not go to camcorder system control. Need to replace that flexible wire by qualified camera tech.
Very rare cases I found touch buttons layer that is pasted and part of LCD becomes defective, do you see hard or deep scratch on LCD surface? if yes, then LCD screen will be replaced because touch button array is damaged.
Thanks.
3helpful
Codes for sky remote control to work the LG32LG tv
I found a few and they depend on the type of remote you have see list below
Remote Code
SKY+ Rev 8/Rev 4 0206
SKY+ Rev 8 1293
SKY Rev 8 1293
I hope they work
3helpful
When I turn on my handycam sony DCR-HC 35,the touch-screen don't work!? What can I do about it?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
2answers
The lcd screen is lit up but none of the touch screen works so i can't access the menu, yet i can still record, but on playback i can't press play rewind etc
touch screen deactivated? checked manual?
to activate you have to put her in play back mode by moving that switch
so please read some basic instruction or let somebody demo it to you :-)
2helpful
Touch screen for Sony DCR HC 32 is not functioning, any suggestions please ?
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.Good luck
Touch LCD points not opeating properly
How often have I heard the phrase - Read the Manual - however I admit to a slight case of panic as I have an important bit of videoing coming up soon....however as the Manual says... The solution to LCD touch screen hotspots not working is re-calibration.
With the Sony DCR-HC22E (also the HC17E/HC19E and HC 21E still Digital Camera this is achieved by
Eject the Tape
Disconnect any Connecting Cables except AC Adaptor or the Handycam Station
Slide the Power Switch Down to turn on the Play/Edit Lamp WHILE pressing the Disp/Batt Info for about 5 seconds
You should then get a screen with a cross in one corner
(The manual recommends touching this with the corner of a memory stick however I GENTLY touched it with a biro. In my case a further 2 crosses appeared and after touching them the LCD Was Re Calibrated.
I re-started my Camera and all the touch spots ( Fast Forward, Menu etc all worked perfectly) Remember you cannot Re-Calibrate with LCD rotated
May 25, 2008 • Cameras
Play/pause/stop/ff/rev/rec not working..
have you tried unplugging the tv for 1 minute and then seeing if it will reset itself. everytime I have had an issue that is the first thing the tech tells me to do. can you call your provider and ask tech for help.
4answers
Lcd screen not working on sony dcr hc 42e
the flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
