Tablets & eReaders Logo
Teej Braily Posted on Oct 04, 2019
How do I Disable rohibited software on my tablet
michael dicker
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Oct 08, 2019
michael dicker
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
863
Points
6
Press Apps
Press Settings
Press Applications
if the App you are looking for is not seen
press Applications Manager
Once you found your app click on it to see the options available.
if it's a default App you can disable it. If it's one you downloaded you can disable or uninstalling it
How can I get my tablet out of the split screen mode and/or disable splitscreen
To disable the split screen go to the Home screen and tap on Apps. Tap Settings. Tap on Multi Window. Tap the Multi Window Switch ( located in the upper right) to enable it disable.
1helpful
How do i enable a disable app on a samsung a tablet
let's start with the basics first in order to solve your app-disable issue. Once we go that, we can move forward as necessary.
settings > apps > click on the app > press "disable" (at top)
The disable button should be to the right of the "force stop" button.
Please let me know if this helped you or not.
How do disable AP on my tablet
Teo, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Turn Off In App Purchases in Smartphones and Tablets
How to Disable In App Purchases in Android
How To Disable In App Purchases For Android Apple Phones Tablets
I bought a sophix tablet from gamestop for my kid and i wanted to disable the browser but when i go to apps - browser - it does not let me disable it (disable button not able to be pushed bc blank) I...
The browser component of the Android tablet is a built in software package. It cannot be easily removed, disabled, or otherwise hidden. However, there are other applications that you can download from the Play market that allow you to mask what applications your child can interact with. These applications, when downloaded, will allow your child only to have access to the parts of the tablet YOU say they can, and nothing else.
Some suggestions:
  • Kids Place - Parental Control
  • Famigo
  • App Lock
While the three above are just the top three in the market that do what you want, there are plenty of others to choose from as well.
When sharing a tablet, phone, or smart device, it is wise to setup an environment that is safe for the other person while still keeping control. These applications allow you to specificy what you want shared, allowed, and available on the tablet, without affecting the operation of the machine. So, they should work for you quite well.
Flash player is blocked
Since the Archos 101 Internet Tablet 16GB 10.1" is running Android 2.2 Froyo, you should be able to install Flash Player. When you say "Flash Player is blocked" what do you see when you try to install Flash Player, what software is blocking the install? Maybe we can disable the software which is blocking Flash Player. The other idea in to go into your settings, usually under security, find and check the box "Allow installation of external programs" then try the install again.
Camera failed
Have you recently messed with your tablet? I recommend doing a factory reset and contacting Samsung about your problem. It is probably just a software problem. You can also check for software updates in the setting section.
4helpful
Hp tablet compaq tc4200.The screen is very dark cannot adjust brightness in control panel.
if you have the quick buttons software installed disable the ambient light :)
17helpful
How do I disable my touchpad on my Toshiba Portege 700?
Toshiba usually set the keys Fn+F9 as the touchpad enable/disable - the touchpad software has to be running in the taskbar to allow this however.
hope this helps 8)
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
