Question about Bosch Dishwashers
Newly installed bosch dishwasher , no power ,no lights on panel- dead ! Power supply 120 v is good Washer plug at rear is well seated ??? Thanks
    Top Expert:
  • Bosch Master
  • 55,370 Answers
Possibly a defective door interlock
Posted on Oct 04, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Bosch dishwasher shu 3302
JiXing Hardware & Mesh Products co.,ltd ,established in 2005, owns two factories in China mainland.
We can supply many kinds of aluminum cooker hood filters,grease filters,,hardware parts,wire shelf,wire and wire mesh.
Our products are sold all over the world , we can assure the good quality with competitive price.
Hope to establish a long-term business relationship with you.
contact info: info@mmfilters.com
TEL:0086-318-7803299
FAX:0086-318-7755255
Posted on Dec 04, 2007
Anonymous
  • 3 Answers
SOURCE: Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Posted on Jan 30, 2008
Anonymous
  • 10 Answers
SOURCE: Bosch dishwasher SHE44CO2UC/22 no power or light
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
Posted on Jun 26, 2009
eagle338
eagle338
  • 4889 Answers
SOURCE: Acer Aspire 7720 shut down, no power light,
The laptop's AC power jack is probably damaged. All you have to do is put the fork aside :D, unsolder the old power jack and solder the new one in. If you are not good at soldering you can get it done by a qualified professional. Its a 5 minute Job and a pretty inexpensive repair.
Regards,
Sai.
Posted on Oct 24, 2009
servtek06
  • 6 Answers
SOURCE: I own a KUDS01FLSS3 KitchenAid
Servtek06 writes:
check connections @ control board/module. May be Control Board/Module.
Posted on Nov 02, 2010
Bosch model SHX68T55UC/02 Completely dead after 2 inch flood in kitchen.
You will need to remove the unit from its installation in the cabinetry. Check the wiring connector located on the rear of the base, near one side. The wire connection must be clean, dry and securely snapped into place. If this connection is burned, distorted or won't allow the plug (special shape) to click securely into place then it should be replaced. Since the unit is totally dead it would appear there is no power reaching the control module, But, you can also confirm that water did not overflow the top of the dishwasher base pan and allow water to enter the pump motors (there are two.) If so these must be thoroughly dried. They may be damaged if power was supplied to a motor with water in the winding and contacts.
Oct 03, 2016 | Bosch Dishwashers
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
How do I change the waste hose on a Bosch Dishwasher Model Number SMS53E12GB the existing hose has been crushed by the base of the machine. I cannot see how I can get to the connection point at the base of...
It is not the easiest thing to do,here is what you have to do;
turn off power supply and water to the dishwasher
remove screws mounting d/w to counter top
remove lower panel
disconnect water and power from d/w
lower legs
pull out from under counter
remove panels covering door hinges
remove linkage from door spring to door hinge
remove the Torx screw securing tub to base frame in the front&rear
pull on base frame to seperate tub from frame about 8-10 inches
remove drain hose from drain pump/install new hose
reassamble in reverse order
Good luck,
Gene
Aug 06, 2011 | Bosch Dishwashers
Bosch dishwaher Model # SHX46A does not display indicator lights and does not function in any mode. There is power to the on/off switch that works and power to the control panel. Other wise the unit is...
Having same problem, power to outlet, but unit is "dead", no lights, won't turn on. Unit is 6 yrs old and don't want to spend $100 for a repair man to tell me there is no hope....anyone else experience this?
Aug 12, 2010 | Bosch Dishwashers
DISHWASHER COMPLETELY DEAD
Hi John, and welcome to Fixya. I don't believe the greasy water sitting in the machine has anything to do with the problem, rather it is likely a by-product of the problem. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
May 25, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Stopped working no power light come on like it's dead.The power supply is fine to the plug and the fuse is ok it just stopped why? is there a reset button anywhere?what would cause this? no hint of a...
check where the pig tail the plug going into the wall follow the plug wire to the connection at the dishwasher. You will need to remove the bottom panel of the dishwasher at the floor. This access panel allows you to see the underneath of the dishwasher. Where the plug wire (pig tail) connects to the dishwasher it is in a small square box on either the right side or left at the front of the dishwasher. Unplug your washer and remove the cover off of this box and check to see if the connections are indeed connected.
Hope this helped
Dave
Feb 17, 2010 | Dishwashers
Cigarette lighter fuse
Here is the fuse relay diagram:
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A). Source(s): http://forums.tdiclub.com/showthread.php?t=122606 fame !
Jul 07, 2009 | 1999 Volkswagen GTI
Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
Apr 26, 2009 | Smeg Dishwashers
GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Oct 16, 2008 | Dishwashers
2003 Volkswagen Golf Problem
it should be number 42
MKIV FUSE LIST
8. Open
17. Open.
42. Radio (25A).
S179. ABS (30A).
Jul 09, 2008 | 2003 Volkswagen Golf
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
