Locks & Locksmithing Logo
Jeffrey Cortis Posted on Oct 04, 2019
I have a brinks round pad lock - tried to open - key must be worn - key almost broke in half. key number M1 0322 0n key- were can i get replacement?
Key broke in lock =can remove it with a magnet?
Richard Fulsom
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 20, 2020
Richard Fulsom
Contributor
Level 1:
Answers
Questions
Helped
398
Points
Your first step would be to contact the lock manufacturer, most will send you a replacement key with confirmation of your model and or Serial #.
5 Related Answers
Anonymous
  • Posted on Sep 16, 2008
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
zr800o1le
zr800o1le
  • 19 Answers
  • Posted on May 12, 2009
SOURCE: stuck door locks
New Keys ....
Anonymous
  • 32281 Answers
  • Posted on Nov 10, 2009
SOURCE: number keys on think pad lock using openoffice.org
On Thinkpads laptops the keys on the right hand side double up as the number keypad. To switch on the Number lock key pad on - press and hold the Shift key and press the NumLk/ScrLk key, it is above the F11 key, the Num lock LED will also light up. Press these keys again to turn off the Numer Lock.
Anonymous
  • Posted on Feb 17, 2010
SOURCE: Need instructions for a Brinks security box with keypad and key
Push button in the back, enter 4 to 6 code and push the pound key.
To check combo push star, enter your code, push pound. Safe will beep three times and turn your key.
Vince Heuser
  • 118 Answers
  • Posted on Jun 16, 2010
SOURCE: liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
How do i get a key replacement for Brinks 5112D key 3706
Brinks 3706 Replacement Key, 0000 - 9999 [SY1 BLANK] ...
EasyKeys.com https://www.easykeys.com > Brinks_0000-9999-SY1-...
Brinks 3706 safe lock replacement key. Hint: The lock code determines the correct key for your lock and will be stamped on your original key or the face of your ...
US$8.87
But it might be a key blank so you need the original. If you have lost it, a locksmith can use an impressioning tool to cut a key.
I have a Brinks Home security safe model 5059. I have lost my only key. is it possible to open without a key? I not how do i get a new key made for this model?
On the lock might be a number, take that to a Brinks dealer who should be able to cut a key! You should have to provide ID for security purposes!
Need to order replacement key mine broke off i have number on key , its a brindk padlock stainless steel number m1 0916
If you have both pieces of the broken key, it can be duplicated.
I did not find that key code listed for Brinks, but perhaps you can get one from Brinks. A locksmith can make a key, check the cost. You really don't want to pay more than the cost of replacing the lock.
Cant open my brinks safe model #5050
I need a replacement key for Brinks model 5050 key # 21
2answers
I have the Brinks safe model 5054. We recently
try taking it to a lock smith it will cost about 15.00 to 20.00 depending who you go to they will make a key or find the combination call a round . good luck
4helpful
2answers
Brinks fire resistant safe model 5059 instruction manual
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
24helpful
9answers
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
