SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
SOURCE: My pioneer vsx-519V-k amp won't turn on. Just
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
SOURCE: Pioneer VSX-515-K A/V Receiver firmware
To download firware for your receiver click on the link below. I hope this helps.
http://www.givemefile.net/firmwares/_av-receiver/pioneer/vsx-ax3-k.html
