SOURCE: how do you mute tv but not headphones?
Look in your TV's menu options. I have an RCA TV which allows me to turn on (or off) the headphone port and set the volume of the headphones. Once you turn the headphone volume up, then you can turn the TV Volume all the way down with your TV remote while the headphone volume remains where you set it. Hope this works for you.
SOURCE: I can't get my wireless headphones to worl wiht my LG 42PG
Salutations Derek23,
Unfortunately that is correct, most newer televisions do not come with "Audio Out" or headphone jacks. Its almost assumed that you would be connecting the television to a receiver or audio source of some type that would have these types of connections.
Sorry to break the bad news.
Jon
Go Ahead. Use Us.
SOURCE: innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
