SOURCE: oil light blinking
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
SOURCE: NEED A WIRING DIAGRAM FOR
Hello, I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
My name is Dane and I am going to try to help you solve your problem.
Here's a link to where you can find your 3000 series service manual. You will find the schematics starting in chapter 17. Please find your correct engine configuration to match the correct schematic.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
