I've tried turning off the machine, unplugging power and network cord, and then restarting, but no change. I haven't changed any settings or setup.
I'd check your Firewall settings on the computer. Is it set to listen to and accept data on the port that the ScanFront uses? If your router has a firewall feature, check if that port is not blocked. Port blocking is the default on many firewalls for data sent from another machine. The default FTP port is given on page 4-12 (page 55 of the PDF) of the user manual: https://files.canon-europe.com/files/soft03-48846/Manual/ScanFront_220_User_Manual_EN.pdf .
Less likely, you should also check the read/write permissions for the destination drive on the destination computer. For some scanning situations, you need to have a monitoring software running to "hear" the send request.
I hope this helps.
SOURCE: Won't turn on
Did you leave it on for the week while you were gone? if so you may have built up **** on the vents of the wii and it will automatically shutdown and not come back on untill it's clear to avoid overheating. Make sure none of your wires are exposed or frayed cuz this will make it shut down too. and I know it's dumb but something the dumbest things can get ya, check that the wall outlet works by plugging lamp into it or something cuz i've had this happen to me. Oh and check and make sure all wires are connected very well
SOURCE: CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
SOURCE: Nokia E71 does not send SMS messages
You have to save all your data first , then you have to format the handset by switch off and then pressing * and 3 and green button and the power button all at the same time un till it asks about country setting and time etc
SOURCE: screen won't turn on - power button continues to f...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: Ricoh Aficio 1027 stopped working
You were able to scan okay before? If you can print but not scan, generally it's a firewall or permission problem. You could try creating an exception for the Ricoh in your firewall software.
The folder that you scan to hasn't moved, has it? Is the path still exactly the same? Try turning off your firewall and/or anti-virus software and see if you can scan then.
