Garden Logo
C
Carl Posted on Oct 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cub cadet mower model GT 2544 pto belt broke replaced with cub cadet belt. Facing the mower from the front the belt comes off the left hand pulley when engaging.
judi indonesia88
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 08, 2019
judi indonesia88
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1106
Points
23
Anda bisa mendapatkan keuntungan yang banyak dalam memainkan taruhan bola. Segera saja daftar di situs kami
https://miniaplikace.blueboard.cz/kniha/0f5f7jkr6mauaec0cc08b6umedjaf4
Jim flowers
Level 3:
  • Cub Cadet Master 1,098 Answers
Jim flowers
Cub Cadet Master
Level 3:
Answers
1098
Questions
Helped
359523
Points
2966
Be sure the belt guides are in place. if they are not in place or bent this will cause the belt to fall out of the pulley.
5 Related Answers
panilling9
panilling9
  • 284 Answers
  • Posted on May 26, 2009
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
panilling9
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Anonymous
  • 10 Answers
  • Posted on Oct 18, 2009
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Anonymous
  • 146 Answers
  • Posted on Jul 07, 2010
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Anonymous
  • 13 Answers
  • Posted on Aug 15, 2010
SOURCE: Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
2answers
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
I have a cub cadet 2186 need to get pto off i wont come off crank
you will have to use large pulley puller to get off it should slide off no problem
2answers
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
1helpful
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
2helpful
3answers
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
2helpful
Cub Cadet zero turn. Cannot get the blades to turn when PTO switch is pulled. Belts are fine and attached. Please help. John
i had the same problem. there was a short in the relay just before the wire gets to to back pulley assembly.
2helpful
Pto blows the fuse everytime i engage it on my rzt 50 cub cadet mower.
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
I have a cub cadet LT1042 and it is 3 years old...we have replaced the pto 2 times and replaced the belt 7 times what is the deal
You have to have something rubbing under there that isn't supposed to be, crawl under the tractor and watch the belt go around by hand, if you can turn it. Maybe see what is frozen up, in the wrong place, Gotta be a belt guide is rubbing or a pulley is not spinning. The PTO should last 20 years, all i can think is they got it too tight to start, .010" min, that is tight, and you must be in Florida picking up a lot of sand? If it was under any kind of warranty, I would raise a big stink about it. Those PTO's are not cheap. And the belt has got to be $20. I wouldn't go to a dealer for the belt, unless it is really special, just match it up at the auto parts store, for half the price of dealer. Hope this helps.
2helpful
3answers
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Daniel Blask
Daniel Blask
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
