Garden Logo
Denny Burnell Posted on Oct 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace rear wheel drive seal on a cub cadet ltx1050kw tractor
Jim flowers
Level 3:
  • Cub Cadet Master 1,098 Answers
  • Posted on Oct 08, 2019
Jim flowers
Cub Cadet Master
Level 3:
Answers
1098
Questions
Helped
359005
Points
2966
Take the wheel off and usually a screw will pull the seal out of the axle housing. clean and replace with new seal. be sure to oil the new seal so it wont bind up and leak
5 Related Answers
joboo1
Jim London
  • 257 Answers
  • Posted on Mar 23, 2009
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Dwain Pippen
  • 377 Answers
  • Posted on Jun 13, 2009
SOURCE: How do I change the drive belt on a 1500 Series
Go to www.partstree.com click on Cub Cadet, enter the model number that's under the seat and that will give you a diagram.
Anonymous
  • 78 Answers
  • Posted on Oct 22, 2009
SOURCE: cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
Anonymous
  • Posted on Nov 01, 2009
SOURCE: Cub cadet LTX 1045 steering problem......... Only
Probably a bent "drag link". See your owner's manual about checking for damage adjusting the steering. For the LTX 1045, it is "Maintenance Section 6", Page 22. If it is bent, repair or replace as mowerman1857 indicated.
You should also lubricate at the two grease fittings (per side) shown on Page 20 -Lubrication - "with a #2 weight Multi-purpose grease". It may have been skipped at the factory or may have been stored at high temperature before you got it, and dried out. (Text in quotes are from the manual)
ROCKIT957
  • 41 Answers
  • Posted on Jul 07, 2010
SOURCE: Ineed to get the belt routing diagrams for the
GO TO INTERNATIONAL PARTS SITE, ENTER TRACTOR MODEL, SELECT PROPER DECK AND THE PARTS LIST HAS A BELT DIAGRAM BUILT IN. IF YOU HAVE AN INTERNATIONAL BELT FOR IT BEAT A PATH TO A BEARING COMPANY TO ORDER THE SAME OR BETTER BELT FOR LESS THAN 1/4 THE IHC COST.
Cub Cadet i1046 Zero Turn Mower won't drive. It is as if brake is on. Belt is okay. Also can't disengage rear drive with levers. Maybe a related problem?
Question edited for clarity, Cub Cadet, not 'club cadet', and added 'what it is.
Question moved to the correct category.
Sounds like you have clutch and drive problems. Take it in for service.
https://www.google.com/search?q=i1046+cub+cadet+can%27t+disengage+rear+drive
Why does the oil light flash on Cub Cadet LTX1050KW after changing oil and oil filter
Most of these reset by themselves after 3 hrs especially after the first oil change. There's nothing wrong and there's no reset button to push. I hope this helps. Take care.
My cub cadet LTX1045 won’t go forward or backwards
https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/LTX1045_769-04349.pdf
First check hydrostat bypass, see page 9 from above link. Transmission is sealed so there's no simple way to check fluid level and if you don't suspect it has leaked there little reason to check. If hydro-bypass is off, then the most likely cause is the traction drive belt. See parts diagram.
https://www.partstree.com/parts/cub-cadet/mowers-lawn-garden-tractor/ltx1045-13wx91at056-13wx91at010-cub-cadet-lawn-tractor-2011/drive-system/
Applying brake causes drive belt to go slack, while releasing brake puts tension on the drive belt. So likely the belt has broken, or brake linkage moved out of place, or belt is so worn it no longer turns the transmission drive wheel.
1helpful
How to fix cub cadet XT1 rear axle seal?
the seal cost about $4.00 take the wheel off and don't lose the wheel key slide off the washer take a screwdriver and pry the old one out and replace with the new one. check your fluid level. if your doing one you might as well do both.
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
2helpful
My Cub Cadet, 15 hrs, will not climb my hill when it is hot, it just stalls, no power to rear wheels, does fine when the tractor is cold, could it be the transaxle ?
Is this unit hydrostatic? If its belt driven it sounds like belt is heating up and stretching causing you to lose friction needed to drive. Have you checked belts?
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Need to replace rear wheel studs on Cub Cadet
They said 7/16-20nf x 1" auto studs are easier. Auto parts stores has
them.
Forward rev shaft seal leaking on 1650 cub cadet
I would say no. your best off to take that in to shop services riding tractors.
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
