Question about RCA Televison & Video
How do I properly program my RCA TV to my amazon 4k fire stick? I can do everything with the remote except for volume and power control of the TV.
6ya staff
SOURCE:
Anonymous
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
Anonymous
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
Anonymous
  • 1077 Answers
SOURCE: Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Posted on Jan 12, 2009
Anonymous
  • 360 Answers
SOURCE: Programming a RCA Remote to a Zenith TV
this link will take you to the RCA site where you can access your remotes codes and instructions (model # of remote is listed on the back or under/inside the battery door in not on the face)
Thanks for using Fix Ya, please take the time to rate this solution.
clarkco.
Posted on Feb 06, 2009
geowelch
  • 14 Answers
SOURCE: Olevia Remote Control Codes
I think you are out of luck. None of the universal remotes recognize Olevia tvs. The manufacturer claims its because they are too new.
Posted on Jul 06, 2009
My fire stick remote won’t respond to Alexa commands from remote
hi Douglas298.
this is all i could find.
Fire TV Remote NOT Responding / Syncing / Connecting: SOLVED I've changed the Fire TV Voice Remote control batteries 5 times already but it still keeps disconnecting and now it's gone completely dead! Update 08/02/17: The most probable cause for your Fire TV remote not working is going to be the batteries. I know, you're thinking I've already changed the batteries twice already. The Fire TV remote is a fickle beast and only likes brand new fully charged batteries before it will re-connect to your Fire TV box. I've tried switching in batteries from other devices that are all working fine, but without any success. Brand new batteries are the key for this power hungry remote.
Has your Amazon Fire TV Box or Fire TV Stick become slow? See my Fire TV Slowdown Solution here.
This need for new batteries seems to be especially true when your Fire TV box is next to a complicated TV setup with AV, Speakers, WiFi Router all next to each other.
AMAZON FIRE TV 4K
AMAZON FIRE TV STICK
If you've tried brand new out of the packet batteries and it's still not working then you might have the same issue I had below. Don't forget to ask any questions you might have in the comments beneath this article.
Update: You can now control you Fire TV Device with the Amazon Echo & Amazon Echo Dot
If you've felt the annoyance of your Fire TV Voice Remote suddenly not connecting then I know how you feel. I've owned a Fire TV since October 2014 and up to now it's handled everything I've thrown at it. This is until one day last week when the remote suddenly kept disconnecting then died completely showing no signs of life.
I went through an array of different fixes to try and get it to work again but then finally I had a brainwave and managed to bring the remote back to life. It wasn't through trawling internet blogs and YouTube videos that I found this solution, it was actually from inspecting the remote more carefully. No, it wasn't Amazon's fault for building inferior products it was actually my own fault and partly the fault of cheap pound stores that litter the UK.
When I took the battery compartment off the Fire TV remote it looked completely normal. It wasn't until I raised the remote up to eye level that I noticed that there was a slight chalky residue on the connectors of the battery compartment. It then dawned on me as I looked across the room at a packet cheap pound shop batteries. One of the cheap batteries had leaked battery acid on to the Fire TV remote connectors blocking the current from getting through.
How to use your Fire TV when the remote won't turn on?
Luckily, Amazon have an App for that called Amazon Fire TV Remote that is available in the Android App Store and the Apple App Store. You can then control the Fire TV using the app and proceed to the next step below.
How to check if your Fire TV remote is connected to your Fire TV?
To see if your Fire TV remote is connecting to your Fire TV box or dongle you need to head to the settings menu.
  1. Settings > Controllers and Bluetooth Devices.
  2. Amazon Fire TV Remotes
This will show you what devices are currently paired and from here you can see if your remote is connecting. In my case when fiddling with the batteries my remote would appear here for a few minutes then disappear.
If all else fails, you can get an official Amazon FireTV Remote replacement.
The Solution
I took a flat head screwdriver and gently scraped the connectors of the Remote at each end. Wiping the residue off with a dry cloth as I scraped. The connector should look shiny and new again at the end of this process. I placed the batteries back in and the remote connected again straight away.
I've had no problems with the remote since and I guess the moral of the story is sometimes you get what you pay for... utter leaky batteries this time.
Fire TV Quick Tips
  1. Hold down the Select button for 5 seconds to put the remote into pair mode.
  2. Hold down the Select + Play buttons together for 5 seconds to Restart the device.
  3. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in.
  4. or try this link.
fire stick remote wont respond to Alexa commands from remote Google Search
Nov 29, 2017 | Televison & Video
Does Fire Stick Support 4K ?
hi Ernest.
The previous Fire TV box already did 4K, but this one can now play it at 60 frames per second and adds HDR (high dynamic range) as a brand new feature to Amazon's streaming devices. ... Amazon has chosen to supportHDR10 but not Dolby Vision for HDR playback. On the audio side, the device offers Dolby Atmos integration.27 Sep 2017
Amazon announces new Fire TV with 4K and HDR for only $70 - The ...
https://www.theverge.com/.../9/.../new-amazon-fire-tv-announced-4k-hdr-price-date-20...
Is the fire stick 4k compatible?4K Resolution. If you have a 4K TV, the Fire TV will help you get the most out of it. This device supports a variety of apps in full UHD resolution, including heavy hitters likeAmazon Video, Netflix and YouTube. The Fire TV Stick, on the other hand, caps out at a full HD resolution of 1080p.27 Sep 2017Amazon Fire TV vs Fire TV Stick: What Should You Buy? - Tom's Guide
What makes 4k so special?A: 4K, also known as Ultra HD, refers to a resolution of 3,840 x 2,160 pixels. That's four times the 1,920 x 1,080 pixels found in your full HD TV.13 Sep 2017..
plus you could go to this link to help you out more.
Does Fire Stick Support 4K Google Search
Nov 18, 2017 | Televison & Video
My amazon is not opening on the tv how can I fix it?
Basic Troubleshooting for Amazon Fire TV Try these common solutions to resolve issues like a blank screen, app errors, and problems with your display or audio.
Can't Connect to Wi-Fi for common solutions that may help.
Amazon Fire TV is Frozen, Blank, or Won't Power On for solutions.
Change Your 1-Click Settings. Manage Your Apps & Games.Contacting Your TV Manufacturer .
About 4K Ultra HD on Amazon Fire TV (2nd or 3rd Generation)Check the Video Resolution section under Display to make sure your connected TV meets HDCP 2.2 system requirements for watching video in 4K Ultra HD. For more information, go to Watching Video in 4K Ultra HD on Fire TV.
Calibrate Your Display
If part of your display is missing or cut off at the edges of your screen, your TV may be automatically scaling your picture.
You can use the Calibrate Display tool (Settings > Display & Sounds > Display > Calibrate Display) to adjust for this.
When you open the tool, you'll see four grey arrows pointing to the edges of your screen, which you can use as a guide when making your adjustments. Press the Up and Down keys on your Fire TV remote until the grey arrows are completely visible and touching the edges of your screen.
Contacting Your TV Manufacturer .Follow the on-screen instructions to make adjustments with your TV remote. You should still see the grey arrows from the Calibrate Display tool--make sure the tips of the arrows are completely visible and touching the edges of your screen.
Amazon Video Settings and Devices on the Amazon website.
Go to the Parental Controls section and enter a new 5-digit PIN under Amazon Video PIN. Then select Reset Your PIN.
MicroSD Storage for Amazon Fire TV (2nd Generation) .
USB Storage for Amazon Fire TV (1st Generation).If your storage device is compatible, try safely removing and then re-attaching it to your Amazon Fire TV:
  1. Select Settings > Device from the Fire TV menu, and then select your storage device.
  2. Select Eject.
  3. Wait for the on-screen confirmation before safely removing the device.
  4. Re-attach your storage device.
Oct 23, 2017 | Televison & Video
Lost my fire stick remote. can my phone be used as a remote?
apparently it can!
Amazon Fire TV (Stick): How to Use Your Phone as Remote Control ...
streaming-blog.com/amazon-fire-tv-stick-how-to-use-your-phone-as-remote/
  1. Cached
  2. Similar
Sep 13, 2015 - Make sure that the Phone with App and the Fire TV are connected to the same Wi-Fi network. ... Enter this code on your Phone. Done. You can see all of the remote apps that are paired with your Amazon Fire TV device under "Settings > Controllers and Bluetooth Devices > Fire TV Remotes".
Amazon.com Help: Download and Pair the Fire TV Remote App
https://www.amazon.com/gp/help/customer/display.html?nodeId=201640980
  1. Cached
  2. Similar
Fire tablets (with a microphone); Amazon Fire phone; Android 4.0 or higher ... Note: The Fire TV Remote App is compatible with Amazon Fire TV devices with ... settings on your router, you need to enable Multicast support to use the app. If you're not sure how to manage these settings, your router manufacturer will be in the ... Lost my fire stick remote can my phone be used as remote Google Search
Dec 31, 2016 | Televison & Video
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Jan 01, 2016 | LG Televison & Video
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Apr 02, 2015 | Amazon Fire TV Stick
Accidently turned off blue tooth
Televison & Video Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
