No voltage on water inlet valve
If the Hoshizaki F-450maf ice machine's reservoir tank has no water, you should first check that the machine is properly connected to a water supply and that the water supply valve is turned on. You should also check that the machine's water filter is clean and not clogged. Additionally, make sure that the float switch is functioning properly and that it is not stuck in the "off" position. If these steps do not resolve the issue, you may need to consult the machine's manual or contact a professional for further assistance.
SOURCE: Water reservoir leaks intermittently
Saeco use the same seal under the grey plastic ring on most of their coffee machines so it should be easy to find a replacement from any Saeco, Spidem or Gaggia service centre.
In most cases the seal isn't worn, it just isn't sitting right, so remove the grey cap (two flat screw drivers to lever from both sides at the same time helps) and reposition it. This is usually all that is needed if the problem is only intermittent.
Also check that there isn't anything sitting in recesses where the legs of the water container sit. It only takes a tiny bit of dirt to stop the container sitting in far enough to seal.
However, make sure the leak isn't coming from the container itself. Hold the container up with water in it and see if it drips. Check the the spring is clean.
SOURCE: Hoshizaki KM-600MAH-E won't start
I don't have a wiring diagram for this machine so I can't be specific, but I may be able to offer a few suggestions. Check for voltage on the coil by slipping the two wires back off their coil connections you should be able to expose enough of the connection to measure voltage. If voltage exists when machine should be filling, you either have a bad coil, or water is not reaching this point. Check coil resistance by removing wires and testing coil. Resistance reading of 0 or O/L (out of range) would be grounds for replacing the coil.
If coil tests good, look for plugged water filters on water line leading to machine.
Hope this helps,
Kermit
SOURCE: replacing water tank inlet valve gasket
Take a screw driver and set it between the chassis and the water inlet, bend the screwdriver and you will hear a "click" sound.
Best regards
/Mirran
SOURCE: LG refrigerator model LRBC22522WW icemaker model
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Testimonial: "Thanks for responding so quickly. I'll use this right away."
