Sewing Machines Logo
B
Bel ange Posted on Oct 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change the lightbulb on the pfaff 7570
Irene Tulloch
Level 2:
  • Expert 498 Answers
  • Posted on Oct 02, 2019
Irene Tulloch
Expert
Level 2:
Answers
498
Questions
0
Helped
119488
Points
994
Bulbs normally release by gently pushing in and twisting.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 14, 2008
SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
sarah28
  • Posted on May 01, 2008
SOURCE: I need service manual for pfaff 7570
also need this manual
TIA
sarah
Anonymous
  • Posted on Jan 15, 2009
SOURCE: Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Anonymous
  • Posted on Jul 01, 2009
SOURCE: 7570 connection
I have Windows Vista; I also had a similar problem; found out that I could only use the usb port on my computer exclusively for sewing as the driver software seems to conflict;
Also, having said that, go to Pfaff.com & download the free driver upgrade and see if that will get you started good luck deb
pfaff907
  • 5 Answers
  • Posted on Dec 15, 2009
SOURCE: connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Blinking Red led on Pfaff 7570
Make sure the bobbin has thread. The manual should provide information in the troubleshooting section.
PFAFF creative 7570 Instruction Book
I HAVE A PFAFF 7570 AND THE BULB BROKE WHILE I WAS REPLACING IT. IS IT POSSIBLE TO OPEN THE SIDE TO REMOVE THE BROKEN BASE?
There are broken lightbulb removal tools but the ones I found are pretty much for regular ceiling lightbulbs and probably wouldn't work on a small sewing machine bulb. There's a tool shown here but I don't know where you would find it.
https://www.pinterest.com/pin/169096160984007738/
Perhaps this would be helpful:
Pfixing the Pfaff (further down the page, it shows how to remove the side cover--after removing the top cover first!)
Be sure to unplug your machine first!!!
You might try using a very long needlenose plier. Stick the needlenose up inside the bulb, then open the pliers until the outside of the nose is tight against the bulb socket and try twisting. If it doesn't grip enough, you might try putting something like a rubber finger over the nose tip. (If there is no broken glass left, you may even be able to put a rubber finger on a fat pencil or even your finger up there and twist.)
Something else that may work is using a fat school eraser, trimming it down to fit in the broken socket.
E326 6 XLT Long Nose Plier with Cutter
Amazon com Swingline Rubber Finger Tips Size 11 1 2 Medium 12 Box 54035...
school eraser Google Search
I would even consider putting super glue on a fat pencil eraser end, sticking it up there and letting it adhere, then giving it a twist.
1helpful
Top sewing foot will not go all the way down
Pfaff creative 7570 Manual
https://www.manualowl.com/p/Pfaff/creative-7570/Manual/184474
Manuals and user guide free PDF downloads for Pfaff creative 7570.
1helpful
Foot leaver will not go down properly
See
PFAFF 7570 User Manual
The only one I found is $40. http://www.sewingstyle.com/pfaff-7570.html You may be able to contact the site for additional information.
I think I would speak with a Pfaff dealer for information before spending this much for a manual.
9helpful
2answers
How to open the top of the Pfaff 7570 machine to clean
Don't bother going in from the top. Don't take out those two screws you see under the handle...they have nuts on the bottom and will drop off. Instead use a Torex screwdriver (think it is #25) and loosen, do not remove, the screw you see down in the left hand space when you raise handle. Screw head is about 2-3 inches down. Use a flashlight. After loosening screw, pull left cover off to expose lightbulb (easy to change now) and other mechanical stuff...you can use compressed air to blow out lint or a brush. Usually not needing oil, but a very little on some of the moving parts helps.
1helpful
6answers
Looking for books or manuals for the Pfaff 7570
happy sewing
http://www.cyberport.net/users/milnerwm/FAQ.html
Pressure foot problem
hi there not sure if the manual will help but if you go to this link you might find it.
pfaff 7570 manual Google Search
or go to this link might help you to find out why.
pfaff 7570 presser foot wont go down Google Search
Bobbin tension
Check also this links, hope they can help you:
Pfaff 1475 7570 7560 FAQ
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
