Vacuums Logo
Mike Riley Posted on Oct 01, 2019
Is it possible that I'm not locking the dirt container when I put it back on why vacuum is totally getting covered with dust and dirt
Steven E Hall
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
  • Posted on Oct 02, 2019
Steven E Hall
Contributor
Level 1:
Welcome Back:
Answers
19
Questions
0
Helped
85136
Points
40
The answer is simple...vacuums with filters allow air and anything finer than the size of the filter holes to pass through...if you hold a light over your bag and turn the vac on, you will see an explosion of fine dust coming from the bag...Vacs work on airflow, so the less air flowing through the bag, the less dirt you pick up...clogged bag = no airflow=no cleaning. Bagless vacs should have the filters cleaned after every use, and the canister emptied and washed. Buy a Rainbow to eliminate these problems.
Elaine Campbell
Level 1:
New Friend:
  • Contributor 36 Answers
Elaine Campbell
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
40613
Points
60
Could be blocked check out the tubes where the dirt goes in
5 Related Answers
Anonymous
  • 1673 Answers
  • Posted on Jan 15, 2008
SOURCE: Kenmore Progressive Bagless vacuum cleaner
Check down by the brush roll to see if the inlet is clogged. This type of problem usually means there is a clog. But you do have a year's warr. on this, if you can't figure it out, then take it a Sears repair shop.
Anonymous
  • 1673 Answers
SOURCE: Upper Filter gets clogged quickly
You may have to replace the filters, air maybe restricted going thru them. The main filter is part #73494, and the foam #74038. Also make sure the SLINGER/CYCLONE ASSY part #74068 isn't clogged up.
advacak
Denny Adams
  • 125 Answers
  • Posted on Dec 02, 2008
SOURCE: my hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Anonymous
  • Posted on Feb 14, 2009
SOURCE: bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Anonymous
  • 281 Answers
  • Posted on Apr 04, 2009
SOURCE: suction problem
check the intake hose at the bottom it may be clogged.try blowing into the long hose if you can't blow through it then you have a clog somewhere between the long hose and your intake hose at the bottom.the intake hose is the somewhat clear hose that comes up from behind the base at the bottom.you will see it on the backside
Dyson dc 33 put more dust in the air from around the seals than it sucks up! Is there a repair that works? I cannot seam to get enough pressure against the seals to keep them sealed.
Hi Jo, it's Jack at Dyson.
DC33 offers a high level of filtration, and the issue of dirt escaping from around the seals between parts would be very unusual. It's possible your machine has been damaged in some way, or that some parts are not correctly assembled.
To help you resolve this we would need to take some additional details, and to talk you through some simple troubleshooting checks when you have your machine easily to hand. If a repair or a replacement part is needed, we'll also be able to confirm whether this is covered under the free Dyson parts and labour guarantee.
When convenient, please give the Dyson Customer Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
I am working on a u5290-900 hover vacuum ,when operating dust leaks out under dirt cup cover. i put a piece of card board on top of cover so extra presure would be applied to the top of cover. this seams...
Dear Sir:
Will be better idea to replace the cup cover. The pice of card will not function for a long time.
Proceed before another extra problem coming.
God bless you
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
My Bissell will not **** up pet hair or dirt
Dirt hair and such will build up in the hoses of that vacum. Take them apart stretch them out and run something through them to make sure they are clean.
The other problem is the filter in the bottom of the cup. At least on some models there is a filter that gets totally pligged with dirt and dust. Take it apart, wash it out and them put everything back together.
Heatman101
2answers
I just bought a foldaway hoover with wide path. I plugged it in and started to vacuum and dust flew everywhere. Walmart would not give me my money back so they gave me another hoover foldaway with the wide...
Take to Walmart, plug it in and start to vacuum THEIR floors!
Try removing the dust container and look for anything blocking airflow including the HEPA filter. Make sure the dust cup has a seal where it joins the vacuum. The fix is probably simple, but it shouldn't be up to you to do so!
2helpful
Vacuum is spitting dirt and debris out the back--what can I do?
the first thing you should do is clean out the container then check the filter if it looks dirty with a lot of dust it probably needs replacing.
check the hoes for dirt that might stick up.if the problem continues it needs a service.
2answers
No dirt is getting to the plastic container.....
if the filters are clean I doubt it! Under the foot of the hoover there should be a little black cover/flap that covers the intake part of the hose, try lifting this flap forward and see if there is any blockage at this end.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
