SOURCE: WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
SOURCE: cyber acoustic mc 1060
For Vista 32 bit. Go to the driver manager. De-instal/delete the driver in the Sound, Video and Game section. In my case it was RealTek High Def Audio ver 6.0.1.5371. (Select Delete the driver files.) Reboot. Vista will reinstall a driver. In my case it was Microsoft High Def audio ver 6.0.6000.16386. I had the mic plugged in when I rebooted to load the new driver. The Cyber Acoustics ML-1060 now works fine. Hope this helps.
SOURCE: Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called
Bosch...was told the same thing...$99.00 for service call. I managed to fix my
problem by doing the following:
The reason I did this was that I figured there must be some more waxy
buildup inside the machine in the cold lines and hoped the hot water would melt
it like when you rinse a greasy pan under hot water.
IT WORKED!!!
I hope this helps you.
SOURCE: My Bosch wfd 1060 fails to drain complety. I have
Check and clean the filter, make sure the outlet hose is not blocked, if all else fails and you are sure the pump is getting a power supply, then replace the pump.
Please rate my solution.
Thanks.
Testimonial: "Great"
http://www.washingmachineadvisor.com/how-do-washing-machines-work-.html
